Results 1 to 10 of 10
Thread: what .ctb did I really want?
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,233
    Cool what .ctb did I really want?
    Howdy y’all,
    I’m seeing a strange thing happening in MAP 2005. When I go to either the print dialog box or to the Layout setup dialog box and I try to set or change the .ctb file that I want, when I pick the name of the file the name two names down is chosen instead. What’s up with that? What can I do to fix it?
    While I’m on the subject is there a way to get that scroll to be longer?
    AutoCAD Civil3D 2013
    Gig 'Em, Aggies!
    Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice
    2005-06
    pleasant hill, ca
    22
    Default Re: what .ctb did I really want?
    I have had that happen to me a couple times as well. Haven't figured out why it does it because it only does it sometimes for me, not always.
    2004-08
    Hartford, Michigan
    3,086
    I'm using regular 2005, I have the same problem with one of our pen table settings, to resolve this issue, I copied the pen table and renamed it something else.
    An alternative solution
    If you can import a page setup from another drawing that has that pen table current, you can get it to stay
    1,233
    What I'm seeing isn't specific to any drawings and not specific to any .ctb files. I wonder if it has to do with the video driver or mouse driver except that the only place this happens is in the plot style table pull-down.
    Gig 'Em, Aggies!
    I could stop if I wanted to Baghera's Avatar
    2002-04
    Halifax NS Canada
    394
    We've run into that problem before as well, it seems as though if you have too mant ctb files in the regular folder it screws things up a little. Try moving some of your less used ctb's to a secondary folder and see if that helps.
    also see here and here
    Loyalty above all else except honor
    For my honor is my life!
    2001-05
    Austin, TX USA
    2,201
    Did you check out this thread?
    CTB issues in 2004
    Quote Originally Posted by Maverick91
    I'm assuming you are meaning to make the list longer so you can see more ctb files at once? Check out QuikPik from ManuSoft.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    1,233
    Quote Originally Posted by Glenndp
    CTB issues in 2004
    So this is yet another issue with no real fix, only work-arounds...
    I've had QuickPik before, but I didn't install it when I upgraded to r2005. I'll help. Thanks.
    Gig 'Em, Aggies!
    1,233
    Dude... not-so-smooth move. After I installed QickPik, I couldn't adjust the size of the fly-outs for Sheet Set Manager, Property Manager, and the other fly-outs (whatever their windows are called). I also could use any of the tabs on their windows. I had to uninstall.
    Gig 'Em, Aggies!
    2001-05
    Austin, TX USA
    2,201
    You have to turn off the locking options in QuikPik or hold the Ctrl button when moving or resizing.
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    1,233
    Ahh, Much better. ( I shoulda' known)
    Gig 'Em, Aggies!
