Results 1 to 8 of 8
Thread: Stair landing problem
    Revit Moderator Tom Weir's Avatar
    2003-11
    639
    Default Stair landing problem
    Hi all,
    I have a short 7 riser stair connecting two levels, with a 6 foot landing that connects to the slab below. There are no risers below the landing.
    The stringers are dog-legged and should extend the entire length of the landing. That's the problem. I cannot get the lower landing to work.
    Presently I just have a slab at the lower level. I would like to get the stringers to work right. Attached is an image of the problem.
    It does not seem that I can produce the landing with no risers below it.
    Any ideas would be greatly appreciated.
    Tom Weir
    Los Angeles
    2003-08
    18
    Default Re: Stair landing problem
    I am not sure if this will help, but I have a similar issue with loading dock stairs. I basically just create the landing as a floor slab, I then do a host sweep - floor slab edge with a profile that matches the stringer.
    2003-11
    639
    I was hoping I would not have to do that. But of course that option might be my only way.
    It seems like I should be able to extend the border somehow but I cannot get it to work.
    Thanks.
    Tom
    2001-12
    Irvine, CA
    7,368
    I'm probably missing something but are you trying to do this? Sorry meant this...new image next to the original.
    2001-07
    Phoenix, AZ
    1,003
    That looks great Steve... but I don't see those option in my stair type... I'm using Revit 8.1 (don't know but don't think we've got the recent updates)
    2004-06
    Memphis TN area
    7,046
    I'm pretty sure those options have always been there, at least since I started in 6.1.
    My vote would also be to uncheck the Begin With Riser parameter.
    AERC, PLLC
    Hernando, Mississippi
    2011-06
    please solve the problem marked in red.....how can i join stair riser with slab......
    its urgent thank you
    I could stop if I wanted to Carlos GT's Avatar
    2005-12
    Orlando, Florida
    234
    Quote Originally Posted by Steve_Stafford View Post
    Steve, how do you create the landing? did you just extend the last stair tread in the sketch mode?
    Carlos Gutierrez
    Drafter/ designer
  1. 2013 - Stair Run / Stair Landing Joins
    By saeborne in forum Revit Architecture - General
    Last Post: 2012-10-04, 03:05 PM
  2. stair landing family
    By Bryan Thatcher in forum Revit Structure - General
    Last Post: 2011-03-21, 01:40 PM
  3. Monolithic stair - bottom landing problem
    By stephen.196528 in forum Revit - Platform
    Last Post: 2008-10-07, 05:38 AM
  4. Adding A landing to a Stair
    By Richard Lopez in forum Revit Architecture - General
    Last Post: 2008-09-10, 10:44 PM
  5. Stair mid-landing height
    By Adam Mac in forum Revit Architecture - General
    Last Post: 2005-06-16, 10:51 PM
