Thread: Configuring tablet menus
    2004-07
    4
    Default Configuring tablet menus
    I would like to import some customization for tablet menu area #1 in Autocad 2006.
    The previous version I had (2002) used configuation files such as acad.mnu that lets you cut-and paste blocks from other menu files. Version 2006 uses ".cui" files that should not be edited with a text editor. At this time I would have to re-write all of my previous commands etc. one at a time into the ".cui" file. This is quite a pain.
    Any help appreciated.
    2001-05
    Austin, TX USA
    2,201
    Default Re: Configuring tablet menus
    Hi yatesfire
    Please note that I have moved this thread from the AutoCAD Customization forum to this one. I believe it would be better served here.
    Thanks
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2001-05
    Austin, TX USA
    2,201
    Try this. Open the acad.mnu file that contains the tablet menus. This should create a CUI version of the file. They you can use the CUI editor to transfer the tablet menus to your new acad CUI.
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
  1. Configuring the menubar
    By michael.lain in forum AutoCAD General
    Last Post: 2010-06-23, 05:09 PM
  2. Configuring a multiport valve
    By rempel08 in forum Revit MEP - Families
    Last Post: 2010-01-29, 03:49 AM
  3. Tablet menus and the Ribbon
    By pete.smith in forum AutoCAD CUI Menus
    Last Post: 2009-10-06, 09:46 PM
  4. Configuring Default Templates etc for Inventor Pro 2008
    By jguest in forum Inventor - General
    Last Post: 2007-11-02, 12:46 AM
  5. Mechanical 2006 - Convert old drafting tablet menus
    By cbear in forum AutoCAD Mechanical - General
    Last Post: 2006-11-20, 03:14 PM
