Results 1 to 7 of 7
Thread: formating text strings
    2004-12
    42
    Default formating text strings
    I am looking for a way in VBA to round text strings which are in decmial to fractions
    example would be 38.875 I would like this to be 38 7/8
    Does anyone have any ideas on this or maybe a script to do this ?
    Anything would be appricated...
    thanks in advance
    Turlock, CA
    6,409
    Default Re: formating text strings
    You can use the DistanceToReal function and specify the acFractional enum for the units argument.
    C:> ED WORKING....
    LinkedIn
    2004-12
    42
    can you please send me an example on how i can use this
    thanks very much
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Quote Originally Posted by rwbaker
    thanks very much
    ' Convert the distance to a real in fractional units
        unit = acFractional
        distAsString = "17 1/2"
        distAsReal = ThisDrawing.Utility.DistanceToReal(distAsString, unit)
        MsgBox "1'-5 1/2"" converts to " & distAsReal & " in fractional units.", , "DistanceToReal Example"
    HTH
    2004-12
    42
    ok i am brain dead... guess i am just fighting this one...
    how can i go from 17.625 to 17 5/8"
    thanks again....
    Turlock, CA
    6,409
    They gave you part of the example out of the help file. You could look there for more info. I was just trying to give you a lead, thinking that you might look it up. But that gives you half the picture, RealToString is the complement. Here is a complete sample.
    Sub testfract()
        Dim unit As Integer
        Dim distAsString As String
        Dim distAsReal As Double
        Dim NewDist As String
        unit = acFractional
        distAsString = "17.625"
        NewDist = ThisDrawing.Utility.RealToString(distAsReal, unit, 3)
        Debug.Print "17.625 converts to " & NewDist & " in fractional units."
    End Sub
    C:> ED WORKING....
    LinkedIn
    2004-12
    42
    thanks to all for the help.....
  1. 2014: Change position of 'text formating' dialogue box
    By prowley459709 in forum AutoCAD General
    Last Post: 2014-05-28, 05:09 PM
  2. text strings on schedules?
    By timsea81 in forum Revit MEP - General
    Last Post: 2009-05-08, 04:30 PM
  3. MText formating - over text
    By Yancka in forum VBA/COM Interop
    Last Post: 2009-01-22, 04:42 PM
  4. spell check removes formating of text?
    By Justin Marchiel in forum Revit - Platform
    Last Post: 2008-01-16, 06:17 PM
  5. Text strings in Dimensions
    By DaveP in forum Revit Architecture - Wish List
    Last Post: 2006-06-26, 12:34 AM
