Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Distance Lisp Routine Help
    All AUGI, all the time BCrouse's Avatar
    2003-04
    Bethlehem, PA
    970
    Default Distance Lisp Routine Help
    Can someone please create a lisp to place a Evacuation Distance Path. The routine should do the following. Use a Polyline, Pick Starting Point and a End Point. Place the Distance in the Attribute provided with the distance rounded to the nearest inch. The Attribute show alway read the same regardless of the direct. Please reference the attachment.
    Thank you,
    Brad
    2004-11
    Somewhere close to hell
    228
    Default Re: Distance Lisp Routine Help
    You might start by saving your drawing down, not everyone is using latest and greatest.
    Rob
    2003-04
    Bethlehem, PA
    970
    I have saved this down to Autocad 2000 version.
    Thank you,
    Brad
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Brad,
    Are you going to select the polyline or does the program need to create it?
    2003-04
    Bethlehem, PA
    970
    Thumbs up Re: Distance Lisp Routine Help
    Quote Originally Posted by richardl.25628
    Brad,
    Richard,
    It would be nice if the program could make the polyline.
    Brad
    2002-01
    jUSt Here (a lot)
    6,836
    Quote Originally Posted by BCrouse
    Richard,
    Brad
    Do you have a sample of what the final product would be, other than your example above?
    Does the polyline contain bends (additional verticies)?
    2003-04
    Bethlehem, PA
    970
    Richard
    Please ref. the attachment for an example for the purpose of this lisp routine. I think that this will answer you second question concerning vertexs in the polyline.
    Please ask if you have anyother questions.
    Brad
    2002-01
    jUSt Here (a lot)
    6,836
    Richard
    Brad
    Brad,
    Try this. It does not draw the flow arrows. If the Attribute Block you first posted is not in the drawing make sure it is within your search path.
    ~Edit~ Attachment removed.
    2003-04
    Bethlehem, PA
    970
    Brad,
    I got it to work, but when I label the line the distance does not show up in the attribute. How hard would it be to put the Directional Arrows in it.
    Thank you,
    Brad
    2002-01
    jUSt Here (a lot)
    6,836
    What was the problem that you were having?
    I'm looking into the arrows.
  1. Surveying Bearing/Distance LISP Routine
    By BoarsNest01 in forum AutoLISP
    Last Post: 2012-09-27, 04:29 PM
  2. Combine three lisp routine into one routine.
    By BrianTFC in forum AutoLISP
    Last Post: 2012-02-08, 11:14 AM
  3. Replies: 9
    Last Post: 2012-01-21, 06:58 AM
  4. Replies: 2
    Last Post: 2011-07-22, 05:32 AM
  5. distance routine
    By hernan.fuentes in forum AutoLISP
    Last Post: 2010-06-22, 02:36 AM
