Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 54
Thread: Distance Lisp Routine Help
  1. #41
    2011-03
    8
    Default Re: Distance Lisp Routine Help
    Hello. I would to change dimension from Inches to Meters in your lisp "Evacroute.lsp". How can I do that?
    Primus
  2. #42
    CORDOBA-ARGENTINA
    275
    Please upload your DWG .
  3. #43
    2011-03
    8
    Here it is.evacroute.zip
  4. #44
    CORDOBA-ARGENTINA
    275
    I mean the DWG where you insert such block
  5. #45
    2011-03
    8
    I would like insert in all my drawings which I am processing.
    In attachment I sending an example.
    Thank you for your efforts. Primuscellar.DWG
  6. #46
    CORDOBA-ARGENTINA
    275
    If you need to see Meters , set your UNITS to Meter, your primuscellar, is set to INCH
  7. #47
    2011-03
    8
    If I change the units in METER, I still write in INCH.
  8. #48
    CORDOBA-ARGENTINA
    275
    The evacuation tag , is 12 acad units , and your cellar , is in inchs , you have to rearrange the evacuation tag to be according to the cellar units , and please set some evacuations routes , just as polylines , start where star shall be and end as end shall be
  9. #49
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    This should work for a drawing with units set to "Meters". Minimal edits were made to make changes to metric distances. Lengths were converted from Inches to equivalent meter lengths. There also appeared to be a infinite loop bug if the distances between picked points was less than the minimum spacing. An additional logic check was added in that spot.
    The previous block attached in this thread should work.
    (defun
          C:EVACROUTE
                     (/           *SYSVAR*    *DOC*       CIRC        LABELPT
                      PLIN        PLIN2       PT1         PT2         PTLIST
                      RTDIST      SPACE       BLOCK-TAGNAME           LAYERCOLOR
                      LAYERLTYPE  LAYERNAME   PLINEWID    TEMP        DTR
                      ARROWLIST   BLOCK-ARROW CIRC-CENTER CIRC-LL     CIRC-UR
                      PLINEWIDTH  SPACE       FINDSPACE   GDESC       GNAME
                      GROUPDESC   GROUPNAME   SPACE       TAG
                      groupss
    ;;; (C) Richard Lawrence
    ;;; Provided as is. No Warranty. Use at your own risk.
    ;;; Permission granted to modify to suit needs.
    ;;; Only system variables changed are listed under
    ;;; Save Settings
    ;;; Evacuation Route V. 1.02 - Metric
    ;;; Replaced values to work for "Meter" based units
    ;;; Added check to flow arrows for spacing is greater than
    ;;;  minimum spacing
    ;;; Evacuation Route V. 1.01
    ;;; Removed requirement of AutoCAD 2005+
    ;;; Added Flow Arrows construction
    ;;; Combined evacuation route entities into a group
      ;; Get current space
      ;; Function provided by others
      (defun
            FINDSPACE
                     (/ *DOC*)
        (vl-load-com)
        (setq *DOC* (vla-get-activedocument (vlax-get-acad-object)))
        (setq SPACE (if (= 1 (vla-get-activespace *DOC*))
                      (vla-get-modelspace *DOC*) ;we're in modelspace
                      (if (= (vla-get-mspace *DOC*) :vlax-true)
              ;thru paperspace VPort
                        (vla-get-paperspace *DOC*) ;we're in paperspace
      ;; Error Handler
      (defun
            *ERROR*
                   (MSG)
        (if (not
              (member
                MSG
                '("Function cancelled" "console break" "quit / exit abort")
          (alert MSG)
        (RESTORE_SYS)
        (command "_.undo" "end")
      ;; Set and Save System Variables
      (defun
            SAVE_SYS
                    (SYSVAR)
        (setq *SYSVAR* '()) ; global var list of saved values
        (repeat (length SYSVAR)
          (setq *SYSVAR*
                 (append
                   *SYSVAR*
                   (list (list (car SYSVAR) (getvar (car SYSVAR))))
          (setq SYSVAR (cdr SYSVAR))
      ;; Restore System Variables
      (defun
            RESTORE_SYS
        (and (listp *SYSVAR*)
             (repeat (length *SYSVAR*)
               (setvar (caar *SYSVAR*) (cadar *SYSVAR*))
               (setq *SYSVAR* (cdr *SYSVAR*))
      ;; Create Layer
      (defun
            MLAYC
                 (LAYNAME COLOR)
        (if (= NIL (tblsearch "layer" LAYNAME)) ; check if LAYER exist
          (command "-layer" "m" LAYNAME "c" COLOR "" "")
              ;if not exist, create LAYER
          (progn
            (command "-layer" "t" LAYNAME "") ; Thaw LAYER
            (command "-layer" "on" LAYNAME "") ; Turn on LAYER
            (command "-layer" "s" LAYNAME "") ; Set LAYER CURRENT
    ;;; Draw Flow Arrows
      (defun
            FLOWARROW
                     (PT1       PT2       /         ANG       ARROWLENGTH
                      ARROWWIDTH          ARW       ARWLIST   CNT       DIST
                      EPNT      EPNTL     EPNTR     MINSPACING          PNT
                      REVANG    SPACE     SPACING   VARIANCE
        (setq ARROWLENGTH
               0.3048
              ARROWWIDTH
               0.2286
              MINSPACING
               1.2192
              VARIANCE
               (* 0.25 MINSPACING)
        (setq DIST    (distance PT1 PT2)
              CNT     2
              SPACING (/ DIST CNT)
              ANG     (angle PT1 PT2)
              REVANG  (angle PT2 PT1)
              SPACE   (FINDSPACE)
        (if	(>= spacing minspacing)
          (while (not (and (>= SPACING (- MINSPACING VARIANCE))
    		       (<= SPACING (+ MINSPACING VARIANCE))
    	(setq CNT     (1+ CNT)
        (setq PNT pt1); (polar PT1 REVANG (- (* 0.5 SPACING) (* 0.5 arrowlength))))
        (repeat CNT
          (setq PNT   (polar PNT ANG SPACING)
                EPNT  (polar PNT REVANG ARROWLENGTH)
                EPNTL (polar EPNT (+ ANG (DTR 90.0)) (* 0.5 ARROWWIDTH))
                EPNTR (polar EPNT (- ANG (DTR 90.0)) (* 0.5 ARROWWIDTH))
                ARW   (vlax-invoke SPACE 'ADDSOLID PNT EPNTL EPNTR PNT)
                ARW   (entlast)
          (if ARWLIST
            (setq ARWLIST (append ARWLIST (list ARW)))
            (setq ARWLIST (list ARW))
    ;;; End Draw Flow Arrows
    ;;; Degrees to Radians
      (defun DTR (A) (* pi (/ A 180.0)))
    ;;; utility to insert a linetype if not already in drawing
      (defun
            INSLTYPE
                    (LTYPE LTFILE /)
        (if (not (tblsearch "ltype" LTYPE))
          (command "linetype" "l" LTYPE LTFILE "")
      ;;__ Save Settings___
      (SAVE_SYS
        '("CMDECHO" "CLAYER" "OSMODE" "PLINEWID")
      ;;__ Set Settings for Function __
      (setvar "CMDECHO" 0)
      (command "_.UNDO" "BEgin")
      (setq LAYERNAME
             "EVAC-ROUTE"
            LAYERCOLOR
             "7"
            LAYERLTYPE
             "HIDDEN"
            PLINEWIDTH
             0.0381
            BLOCK-TAGNAME
             "EVACUATION DISTANCE TAG"
            GROUPNAME
             "EVAC-RT"
            GROUPDESC
             "Evacuation_Route"
      (if (not GROUPNO)
        (setq GROUPNO 65)
      (setvar "PLINEWID" PLINEWIDTH)
      (MLAYC LAYERNAME LAYERCOLOR)
      (if (not
            (= "Continuous"
               (cdr (assoc 6 (setq TEMP (tblsearch "Layer" "EVAC-ROUTE"))))
        (command "-layer" "ltype" "Continuous" LAYERNAME "")
    ;;; insert block definition if not already in drawing
      (if (not (tblsearch "block" BLOCK-TAGNAME))
        (progn
          (if (findfile BLOCK-TAGNAME)
            (command "-insert" BLOCK-TAGNAME NIL)
            (progn
              (alert
                (strcat
                  "Block: "
                  BLOCK-TAGNAME
                  " not found in search path.  Verify location and retry."
              (quit)
        (progn
          (setq SPACE (FINDSPACE))
          (prompt "\nCreate Evacuation Route")
          (setq PT1       (getpoint "\nSpecify Beginning of Route: ")
                PTLIST    (list (car PT1) (cadr PT1))
                PT2       (getpoint PT1 "\nSpecify next point: ")
                RTDIST    0.0
                ARROWLIST NIL
          (while PT2
            (if PLIN
              (entdel PLIN)
            (setq RTDIST (+ RTDIST (distance PT2 PT1))
                  PTLIST (append PTLIST (list (car PT2) (cadr PT2)))
                  PLIN   (vlax-invoke SPACE 'ADDLIGHTWEIGHTPOLYLINE PTLIST)
                  PLIN   (entlast)
            (if ARROWLIST
              (setq ARROWLIST (append ARROWLIST (FLOWARROW PT1 PT2)))
              (setq ARROWLIST (FLOWARROW PT1 PT2))
            (setq PT1 PT2
          (setvar "osmode" 512)
          (setq LABELPT (getpoint "\nSpecify label location: "))
          (setq CIRC (vlax-invoke SPACE 'ADDCIRCLE LABELPT 0.3048)
                CIRC (entlast)
          (setq CIRC-CENTER
                 (cdr (assoc 10 (entget CIRC)))
                CIRC-LL
                 (polar (polar CIRC-CENTER (DTR 270.0) 0.3556)
                        (DTR 180.0)
                        0.3556
                CIRC-UR
                 (polar (polar CIRC-CENTER (DTR 90.0) 0.3556) (DTR 0.0) 0.3556)
          (command "zoom" "Window" CIRC-LL CIRC-UR)
          (command "trim" CIRC "" LABELPT "")
          (setq PLIN2 (entget (entlast))
                PLIN  (entget PLIN)
          (if (assoc 43 PLIN)
            (setq PLIN (subst (cons 43 PLINEWIDTH) (assoc 43 PLIN) PLIN))
            (setq PLIN (append PLIN (list (cons 43 PLINEWIDTH))))
          (if (assoc 43 PLIN2)
            (setq PLIN2 (subst (cons 43 PLINEWIDTH) (assoc 43 PLIN2) PLIN2))
            (setq PLIN2 (append PLIN2 (list (cons 43 PLINEWIDTH))))
          (entmod PLIN)
          (entmod PLIN2)
          (entdel CIRC)
          (command
            "-insert"
            BLOCK-TAGNAME
            LABELPT
          (setq TAG (entlast))
          (vla-put-textstring
    	(vlax-ename->vla-object (entnext (entlast)))
    	(rtos RTDIST 2 0)
          (setq GROUPLIST (append
                            ARROWLIST
                            (list (cdr (assoc -1 PLIN)) (cdr (assoc -1 PLIN2)) TAG)
                GNAME     (strcat GROUPNAME "-" (chr GROUPNO))
                GDESC     (strcat GROUPDESC "_" (chr GROUPNO))
                GROUPNO   (1+ GROUPNO)
          (setq groupss (ssadd))
          (foreach n grouplist (setq groupss (ssadd n groupss)))
          (command "-group" "Create" GNAME GDESC GROUPss "")
          (command "zoom" "Previous")
          (INSLTYPE LAYERLTYPE "acad.lin")
          (command "-layer" "ltype" LAYERLTYPE LAYERNAME "")
      (command "_.UNDO" "End")
      (RESTORE_SYS)
  10. #50
    2011-03
    8
    Thanks. Works superb.
  1. Surveying Bearing/Distance LISP Routine
    By BoarsNest01 in forum AutoLISP
    Last Post: 2017-03-02, 10:19 PM
  2. Help with a lisp routine to add a 12" line to this routine
    By Orbytal.edge341183 in forum AutoLISP
    Last Post: 2012-11-14, 10:33 PM
  3. Combine three lisp routine into one routine.
    By BrianTFC in forum AutoLISP
    Last Post: 2012-02-08, 12:14 PM
  4. Replies: 9
    Last Post: 2012-01-21, 07:58 AM
  5. distance routine
    By hernan.fuentes in forum AutoLISP
    Last Post: 2010-06-22, 02:36 AM
