Richard,Originally Posted by richardl.25628
What would cause to routine to stall out. I has been happening when I start. It also stalls out when I try to add another route .
thank you,
Brad
thank you,
Brad
Could you add the option for arc in the routine?Originally Posted by BCrouse
Thank you
It stalls out after 1?Originally Posted by richardl.25628
Probably not at this time. If I have more time, I will see what I can do.Originally Posted by BCrouse
Have you done any other routes in that drawing since it started working?Originally Posted by BCrouse
It could be the grouping of the objects. To disable the groups, place semi-colon at line 317. I will look into fixing that portion, or completely removing the grouping.
I'lll do that .Originally Posted by richardl.25628
Thank you,
Brad
I did that and it seems to be stalling out when I try to do a short distance. But when I do long distances it is working okay.Originally Posted by BCrouse
Thank you,
Brad
Richard,Originally Posted by BCrouse
This routine is still locking up when I have a short distance point and then change the direction to continue with the evacuation route. Do you have any other suggestions? I place semi-colon at line 317 to disable the grouping. But bit its still locking up.
Thank you,
Brad
Brad,Originally Posted by BCrouse
I'll need to look at it next week. Can you send some example dwgs of what you are doing?
