Page 6 of 6 FirstFirst ... 23456
Results 51 to 54 of 54
Thread: Distance Lisp Routine Help
  1. #51
    2011-03
    8
    Default Re: Distance Lisp Routine Help
    Hello again.
    I wonder if the Lisp can be edited so that the EVAC-ROUTE layer is set not to print? (Layer Properies Manager> no-plot function).
  2. #52
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Sure it can. I'm not going to code that, though. Please look at the Create Layer function in the posted code. It starts off with
      ;; Create Layer
      ;; Function provided by others
      (defun
            MLAYC
    Somewhere in that function, you could add the necessary code to handle this request.
  3. #53
    2005-06
    CORDOBA-ARGENTINA
    275
    On Opie permit
    ;; Create Layer
    (defun
    MLAYC
    (LAYNAME COLOR)
    (if (= NIL (tblsearch "layer" LAYNAME)) ; check if LAYER exist
    (command "-layer" "m" LAYNAME "c" COLOR "" "")
    ;if not exist, create LAYER
    (progn
    (command "-layer" "t" LAYNAME "") ; Thaw LAYER
    (command "-layer" "on" LAYNAME "") ; Turn on LAYER
    (command "-layer" "s" LAYNAME "") ; Set LAYER CURRENT
    (command "-layer" "P" "n" LAYNAME "");set layer to NO PLOT
  4. #54
    2011-03
    8
    You're great. Thank you for your time.
    Primus.
  1. Surveying Bearing/Distance LISP Routine
    By BoarsNest01 in forum AutoLISP
    Last Post: 2017-03-02, 10:19 PM
  2. Help with a lisp routine to add a 12" line to this routine
    By Orbytal.edge341183 in forum AutoLISP
    Last Post: 2012-11-14, 10:33 PM
  3. Combine three lisp routine into one routine.
    By BrianTFC in forum AutoLISP
    Last Post: 2012-02-08, 12:14 PM
  4. Replies: 9
    Last Post: 2012-01-21, 07:58 AM
  5. distance routine
    By hernan.fuentes in forum AutoLISP
    Last Post: 2010-06-22, 02:36 AM
