Results 1 to 10 of 10
Thread: Background mask default offset
    2002-08
    21
    Default Background mask default offset
    Is there a way to change the default border offset for the mtext background mask from 1.5 to 1?
    0,0,0 The Origin
    8,027
    Default Re: Background mask default offset
    Quote Originally Posted by djohnson.35902
    From A2006 Help -
    Draw toolbar:
    Draw menu: TextMultiline Text
    Command line: mtext
    Controls use of an opaque background behind text.
    Use Background Mask
    Puts an opaque background behind the text.
    Border Offset Factor
    Specifies the margin around the text for the opaque background. The value is based on the text height. A factor of 1.0 exactly fits the multiline text object. A factor of 1.5 extends the background by 0.5 times the text height.
    Fill Color
    Specifies the color for the background.
    Use Background Drawing Color
    Provides a background that is the same color as the background of the drawing.
    Color
    Specifies a color for the opaque background. You can select one of the colors in the list or click Select Color to open the Select Color dialog box.
    What it doesn't tell you is that it's found under the down-pointing-arrow-in-a-circle.
    HTH
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2002-08
    21
    I am using 2005 and I don't understand your comment "down-pointing-arrow-in-a-circle". I know how to change the border offset through the mtext editor. I prefer it to be set to 1 and don't want to change this everytime. I would like to change what the default setting is but don't know how.
    I could stop if I wanted to Baghera's Avatar
    2002-04
    Halifax NS Canada
    394
    Not the answer your looking for but it might do the trick. This LISP was written by Lee Ambrosius. It allows you to set the colour and offset before you pick multiple instances of mtext.
    Loyalty above all else except honor
    For my honor is my life!
    Active Member amy.stuart's Avatar
    2004-05
    nebraska
    88
    Okay am I missing a setting or something? my background mask will not change from 1.5" i try any other number within the recommended numbers from 1.5 - 5. Why is this? Another user can open the exact same drawing and change the setting off of 1.5.
    Thanks.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    So I assume no one has found a way to change the default background mask border offset? I can't find one in 2006.
    I just upgraded from 2004, and I ran into this issue as soon as I tried using the background mask option. Since the problem also existed in 2005, I'm (slightly) surprised that it wasn't fixed for 2006. It seems like an obvious blunder.
    In the meantime, Lee's lisp routine provides an adequate (if annoying) workaround. Thanks for writing it, Lee.
    150700
    3,421
    It is not possible to change the offset, however, this has been submitted to the wish list and is one of many wishes on the current ballot. If you haven't already done so, now is a GREAT time to go vote for your top 10!!!
    2009-12
    NJ
    the wizardry you bright people bring to this site never ceases to amaze me. Thanks!!!!
    AUGI Director scott.wilcox's Avatar
    2001-01
    Edmonton, Alberta
    961
    I set my background mask to 1.2, instead of the default 1.5
    Why draw straws? Just draw one straw and array it.
    Scott Wilcox - Edmonton, Alberta
    2009-03
    3
    Quote Originally Posted by scott.wilcox View Post
    How did you do that Scott?
  1. Background Mask
    By pants in forum AutoCAD General
    Last Post: 2010-10-13, 09:39 PM
  2. Change the border offset for mtext background mask
    By Tom Beauford in forum Autodesk Labs Wish List
    Last Post: 2010-05-19, 03:33 PM
  3. Background mask default offset - Dimension Text
    By joshua.andersen in forum AutoLISP
    Last Post: 2009-12-09, 03:49 PM
  4. Using BACKGROUND MASK with DWF
    By clarkrj in forum Design Review - General
    Last Post: 2008-01-22, 08:26 PM
