Thread: Changing revision number tag how?
    2001-07
    477
    Default Changing revision number tag how?
    I need to change the number on the revision tag it always show numbre 1 i tried to change to numbre 2 but it keeps showing revision number 1 how do I change that.
    Thanks
    2003-08
    Vancouver, BC Canada
    3,394
    Default Re: Changing revision number tag how?
    You must first create a new revision under the Settings menu. Once done you should be able to assign the revision number to the tagged cloud. Select the cloud and under properties you should have all revisions available to you.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
  1. Revision Number vs. Sequence
    By twollifur in forum Revit Architecture - General
    Last Post: 2010-07-12, 01:13 AM
  2. Revision Cloud With Number
    By SHAJU in forum AutoLISP
    Last Post: 2009-05-20, 07:50 PM
  3. Current Revision Number
    By nextvkin in forum AutoCAD Fields
    Last Post: 2009-01-19, 10:37 AM
  4. Revision Cloud without Number
    By veronica.lamb in forum Revit Architecture - General
    Last Post: 2006-10-23, 08:42 PM
  5. REVISION NUMBER
    By Alvin_Alejandro in forum Revit Architecture - General
    Last Post: 2005-05-12, 02:54 PM
