Is it possible in Revit to create a schedule with formulas that will generate the actual BOMA calculations using the 1996 standard? Has anyone tried this? If not, what do you all do when you are contractually required to provide this information? Are you doing the same export thing I was forced to use with ADT schedules? Has anyone tried the Access export and gotten it to work for BOMA calculations? I have done this in ADT/Excel for buildings from 2 to 28 floors and I pretty much hate doing it. I know I can get the raw data easily from Revit but it's the formulas and complexity that's the challenge.
I am willing to add to my task list and tackle the problem eventually, but if anyone has determined it's hopeless already, I will not bother.
Attached is a PDF of an XLT file I created for generating true BOMA calculations based on the 1996 standard. It was a pain to create, it is complicated to get correct, and I cannot link the information to ADT schedules we currently use. We have successfully exported the ADT schedule and managed the raw data with a copy-paste fairly successfully but it's still a pain and it's not an active link. The number of steps wherein user error could trump the result is too high.
Thank you,
PBR
