Thread: fatal error when rendering or setting up a new view
    Active Member Kaotik's Avatar
    2015-10
    Los Angeles, CA
    68
    Default fatal error when rendering or setting up a new view
    this project im working on is a simple monument with nothing special about it. almost the smallest project ive done so far. and yet if i try to set up a new view or render the one view i did set up, it locks up and shows a fatal error. I dont understand whats going on but i need this project done so any help would be greatly appreciated! im attaching the file so if someone could figure out how to get this fixed it would be nice.
    thank you for your time,
    Brian Andresen
    Andresen Architecture Inc.
    I could stop if I wanted to kpaxton's Avatar
    2004-12
    Sarasota, FL
    493
    Default Re: fatal error when rendering or setting up a new view
    Ummm.. Which version are you using?
    There is a new update out on 9/15 available for download. The first release of 8.1 is a bit buggy for people on certain machines.
    -Kyle
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    It might also be a corrupt element such as a tree that maybe causing the crashes upon render.
    Check the journal file to see if this reveals anything also it maybe an idea to do an audit on the file.
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
  1. 2012: Revit mep: Export to dwg fatal error. Sync fatal error as well
    By Scottybill in forum Revit MEP - General
    Last Post: 2012-11-30, 09:47 PM
  2. Fatal Error with Rendering Dialog
    By matthewh.104177 in forum Revit Architecture - General
    Last Post: 2008-09-18, 01:25 PM
  3. 2009 bug0 fatal error when editing RVT links of View Templates
    By twiceroadsfool in forum Revit Architecture - General
    Last Post: 2008-05-27, 03:07 PM
  4. Fatal error when modifying view templates
    Last Post: 2008-04-29, 02:20 PM
  5. Fatal Error with Radiosity Rendering?
    By twiceroadsfool in forum Revit - Rendering
    Last Post: 2006-02-09, 05:49 PM
