Thread: Random rows appear in OLE object
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    Default Random rows appear in OLE object
    I am seeing a random number of rows when I insert a spreadsheet as an OLE object.
    Is there a way I can control the number of rows that appear?
    Sometimes the text I want to see gets cutoff at the bottom of the
    inserted picture.
    2001-03
    13,499
    Default Re: Random rows appear in OLE object
    Hi
    For starters work your way through all! the links within the following thread found in the AutoCAD FAQ forum -
    Working with OLE (eg Excel) Objects within a drawing file
    Have a good one, Mike
  1. 2010: Delete or Add Rows
    By eyde in forum AutoCAD Tables
    Last Post: 2012-03-29, 10:04 PM
  2. Can Rows in Sub-Panels pan?
    By Liamnacuac in forum AutoCAD CUI Menus
    Last Post: 2011-10-12, 12:14 PM
  3. Used rows count
    By rorygodsell in forum VBA/COM Interop
    Last Post: 2009-04-09, 12:44 PM
  4. Hiding rows or columns
    By irneb in forum AutoCAD Tables
    Last Post: 2008-01-17, 06:37 PM
