Results 1 to 7 of 7
Thread: upgrade to 8.1 crashes
    I could stop if I wanted to Chirag Mistry's Avatar
    2004-06
    Atlanta
    254
    Default upgrade to 8.1 crashes
    We were trying to upgrade our file to 8.1, REVIT keeps crashing...tried mulitple times..no luck. I get this " An unrecoverable error has occured. The program will be terminated"
    also, got the attached error one time. Please help
    Thanks
    I could stop if I wanted to rhys's Avatar
    2003-05
    Cotswolds, UK
    433
    Default Re: upgrade to 8.1 crashes
    Quote Originally Posted by chiragmistry
    Thanks
    Thats a file to send to support - assuming it is happening after you have opened with the AUDIT option
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    That's a good point, Rhys. We haven't had that option in the past!
    2004-06
    Atlanta
    254
    Smile Re: upgrade to 8.1 crashes
    Whew....figured out what the probelm was.
    When contacted Autodesk...this is what they had to say,
    Our development team found the issue to be circular refence files withing your xrefs. This should clean up the issue you were having.
    Caused by circular xrefs. Same behavior in 8.0 - not a regression.
    Something to be aware of for this or future upgrades.
    Thanks
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,233
    Do you mean circular xrefs within drawings linked to your Revit model? Unless I'm missing something, I don't remember when Revit used xrefs
    2004-06
    Atlanta
    254
    Exactly Brad...do not have circular references in the autocad file linked to REVIT
    2001-12
    Irvine, CA
    7,567
    Thanks
    Thanks for sharing this!!
  1. Revit 2013 upgrade yet? - softaware stability, crashes & bugs
    By andrewharle in forum Revit Architecture - General
    Last Post: 2013-01-08, 09:10 AM
  2. Replies: 0
    Last Post: 2010-04-01, 03:21 PM
  3. ADT CRASHES
    By Chuckyd67 in forum ACA General
    Last Post: 2006-11-07, 06:17 PM
  4. Upgrade the Upgrade Utility
    By ctc in forum Revit Architecture - Wish List
    Last Post: 2006-09-26, 01:58 PM
  5. Crashes after Upgrade.
    By Paul Monsef in forum Revit Architecture - General
    Last Post: 2004-01-26, 08:45 PM
