Thread: Pack n Go Problems
    2003-12
    The Hammer
    88
    Default Pack n Go Problems
    I have 2 concerns on sending assemblies to my customers:
    1) When I use the Pack n Go utility all the components from the ipart centre are listed as unresolved parts. What do I have to do to ensure that they are resolved?
    2) Is there a way to give my customer a fully scaled assembly that he can move around, place into his assembly, but it is only a single item so that he can take apart the parts and start to reverse engineer. Also the folders I create are massive and I don't want to send such a large folder through the internet.
    Looking forward to your response.
    Manufacturing Moderator jonathan.landeros's Avatar
    2005-03
    Los Angeles County, Ca.
    440
    Default Re: Pack n Go Problems
    Quote Originally Posted by bmichell
    1. I'm not completely sure on this one (I haven't done a P&G on I-parts). Make sure you uncheck 'skip libraries' (if available). Also make sure that you hit both 'Search Now' buttons. This will at least make sure that you do the deepest search possible.
    2. You could go to step or sat, this puts everything into one file. Another option would be to derive the assembly into a single part, and export the step or sat of that. The volume and geometry will be there, but it will be a 'dumb solid' with no feature history. This would give you the flexibility to let them reverse engineer everything, or you could fill voids, etc, and remove information if you didn't want them to reverse engineer it.
    Jonathan
    Jonathan Landeros
    KETIV Technologies
    Orange County, California.
    I've got a blog: www.inventor-tales.blogspot.com
    “We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
    2003-12
    The Hammer
    88
    Thanks for your input Jonathon. I've derived the assembly into a single part and saved it as a step file. This will allow my customer to place the part in his model and check interferences etc. I'm not worried that my customer will reverse engineering (I prefer to call it copying) the parts.
    I'll work on the pack and go later today.
    Brad
  1. Pack and Go
    By leoleo in forum Deutsch - Inventor
    Last Post: 2009-09-03, 05:18 AM
  2. Pack-n-go
    By bnia in forum ACA General
    Last Post: 2005-05-12, 04:53 PM
  3. Pack & Go
    By vmidp in forum AutoCAD LT - General
    Last Post: 2005-04-20, 07:10 AM
  4. Pack-N-Go
    By jimmy.long in forum MDT - General
    Last Post: 2004-10-28, 03:50 PM
  5. Pack 'n go
    By nigel.chesworth in forum AutoCAD General
    Last Post: 2004-10-14, 03:49 PM
