Thread: Paperspace Text Plots slightly thinner than Modelspace Text
    2005-08
    5
    Smile Paperspace Text Plots slightly thinner than Modelspace Text
    I notice that some of my text, being the same color, plots out slightly less thick in paper space than in model space. What can I do to change this? Advice needed. Thanks!!!
    2001-03
    13,499
    Question Re: Paperspace Text Plots slightly thinner than Modelspace Text
    Hi
    Are you using SHX or TTF fonts?
    What font (name) are you using?
    Does it occur with all drawing files or just the odd one or two?
    Does it occur on all output devices or just one particular output device?
    Have a good one, Mike
    2005-08
    5
    Default Re: Paperspace Text Plots slightly thinner than Modelspace Text
    Thank you.
    I'm using the same color, with Swiss721 EX BT style. It really looks different in the plot preview but only slightly different in the final plot on a HP500 inkjet. It happens with all the plot on that machine, the others are too large of a scale to notice.
    2001-03
    13,499
    Quote Originally Posted by jeattende
    Hi
    Seeing as you are using a TrueType font, see if the links in the following two posts offer any help...
    RE: Unable to select mtext
    RE: Plot quality is....... unknown!!!
  1. Revit 11x17 plots slightly clipped top/bottom
    By vanderloo5 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-01-25, 07:28 AM
  2. Draworder - Image in Modelspace, Text in Paperspace
    By tmorrow91 in forum AutoCAD General
    Last Post: 2006-07-18, 09:14 PM
  3. Text in paperspace is hidden by image in modelspace
    By chrisr in forum AutoCAD General
    Last Post: 2006-07-17, 07:26 PM
  4. Benefits (or not) of Paperspace vs. Modelspace text
    By sschwartz in forum CAD Management - General
    Last Post: 2006-05-03, 10:28 PM
  5. TEXT PLOTS AS SQUARES
    By rtorres in forum AutoCAD General
    Last Post: 2005-09-30, 10:02 PM
