Results 1 to 10 of 13
Thread: shadows on elevations
    2003-10
    92
    Default
    I'm sure that this has been asked before, but without rendering, what is the quickest way to put shadows on elevations. I've been told that this is automated in archicad, but you have to manually do it in revit. We have invested in a number of seats of revit, but my directors keeps asking for this functionality. Any ideas would be welcomed.....
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Default Re: shadows on elevations
    There is no shadowcast in Revit unless you use the rendering tools.
    The cheapest option may be to spend £300/$500 on Sketchup and export the model to that!
    Pete
    2003-10
    92
    Cheers for that Pete.... I've tried another work around, which I think Beegee posted last year. Rendered out the elevation; overlayed the wire framed elevation over the render & approx. traced the shadows using the region fill tool. You get a reasonable result. I've also emailed Revit support asking isf this could be added to the wishlist. Lets see if they can get it in V7.
    2002-02
    St. Louis, MO
    4,695
    ...we are putting shadows on elevations as I speak. We do a quick rendering of the shadows. Drop it in photoshop and "magic wand" then out by themselves - color doesn't matter as we just filter out the shadows as an object and then adjust the contrast/color in photoshop.
    From here there are a couple of options. Use Illustrator to combine exported linework and shadows. Or use AutoCAD linework and import a Tiff into AutoCAD.
    Does involve a couple of steps outside of Revit, but so far has proven pretty quick and the images look quite good.
    I tried using Sketchup, but found that it just couldn't keep up on the larger models I wated to export.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    2003-04
    London, UK
    1,948
    Can you post an example, please, Aaron
    Pete
    2002-02
    St. Louis, MO
    4,695
    ...sure. I'm out of upload space here, but I've got some posted @ ftp://ftp.kai-ae.com/ARCH/Revit/
    This is for an SD phase of work for 255 units of housing. I'm showing a shadow image we take from Revit to photoshop and then a merged linework/shadow. No retouching or cleanup has been done to the final image. We've have quite a few different building types to do, so we needed something that we could do quickly.
    Aaron Rumple, AIA
    2003-05
    5,153
    Quote Originally Posted by aaronrumple
    So, to clarify Aaron, once you have separated the shadows in PS, you export them as a tiff to Illustrator, where you combine them with an export of the building hidden line elevation out of Revit ?
    Sounds like a bit of work.
    I'm looking into SketchUp to do this as well as give the hand-drawn quality to sketches.
    Have you nay details on the max size of the Revit file before SkechUp chokes ?
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    100 Club Vincent Valentijn's Avatar
    2003-07
    netherlands
    188
    Quote Originally Posted by beegee
    I've put some big files into Sketchup, I'd estimate that for my configuration (P4 2Ghz/512Mb/GeForceMX300) the maximum workable filesize of a 3D dxf is about 25 to 30Mb's.
    On that size it still edits and generates shadows reasonably quick in hidden view... on rendermode it's too sluggish though.
    I could stop if I wanted to robmorfin's Avatar
    2003-10
    Solana Beach, CA
    200
    Tracing Region Fills,
    Render-Photoshop-Illustrator-Revit again,
    Render-Photoshop-Tiff-AutoCAD-Revit again,
    Sending from Revit to Archicad seems to be the fastest way to get the shaded Elevations, Do Revit Developers want us to do that, or are we getting that option sometime soon??
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    Do you mean Sketchup? It seems unlikely that there will be specific support for Archicad-Revit file compatibility before there is support for ADT, MAX, VIZ, etc. I would see Sketchup interoperability supported before Archicad...could be wrong though.
  1. 2013: Printing elevations with shadows on
    By albino394381 in forum Revit Architecture - General
    Last Post: 2013-10-31, 03:11 AM
  2. 2013: Printing elevations with shadows on
    Last Post: 2013-10-22, 04:36 PM
  3. Shadows in Elevations or Sections
    By iankids in forum Revit Architecture - General
    Last Post: 2010-10-01, 12:22 PM
  4. Printing elevations w/ shadows
    Last Post: 2005-12-16, 02:54 PM
  5. Sun Shadows on Elevations
    By aalomes in forum Revit Architecture - General
    Last Post: 2004-10-29, 06:10 PM
