The new text editor displays the measured value when editing dimension text (please don't ask why I need to edit it).
Is it possible to make the editor diplay the <> default value indicator instead?
John B
"With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
Hi
Having still not loaded AutoCAD 2006 (in box sitting on my desk) I can't give you a direct answer to your question, but the following should work as a workaround (if acceptable)...
Edit via Properties Palette
or
Use the "old" style Multiline Editor ( mtext - vertical text )
or
Set MTextEd to use something like NotePad.exe
or
Have a good one, Mike
Thanks Mike.
I was hoping for something rather more direct.
Perhaps I'll just produce a macro to change to the old editor, edit and reset to the new editor.
John B
HiOriginally Posted by johnbogie
Try this post - RE: mtext - vertical text (offers one method).
Hi Mike.
Yes. I'll use that until a better way appears.
BTW, I've called the function c:TET (TextEditorToggle) because it's easy to type.
Thanks
John B
