Results 1 to 6 of 6
Thread: EXPORTING LAYER to autocad
    2004-11
    115
    Default EXPORTING LAYER to autocad
    1.I've had read sometime ago that viewport can be assigned to layer when exporting to Autocad. but I can't find where in the export.Please help.
    2.The left image is revit & the 2nd is autocad. In revit sheet view my title block is in A1 portrait layout in some reason. And the Question is that when I exported it to autocad the inserted company logo(image jpg) was not rotated.
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    Default Re: EXPORTING LAYER to autocad
    1. You should have a viewport category set in your export layers file... If you're using a previously created layers file it may not have the viewport layer included. open an 8.1 layers file in a text editor and simple copy that to your layers file.
    2. Strange haven't experienced this before, but i don't usually rotate images. Was the titleblock created in this format or has it been rotated in the project?
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
    2003-05
    5,153
    To check your viewport export setting ... File > Export >Options > Layer Settings. ( new in 8.1 )
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    2004-11
    115
    Quote Originally Posted by Mr Spot
    Ans: you're right I've used my previous created layer file, I see it already.
    Ans:Yes, its created in this format and no it is not rotated. but the image.jpg was rotated in the family.
    Thanks..and to Beegee for illustration..
    2003-05
    5,153
    Alvin,
    I ran a test in 8.1.
    The raster images did rotate, but are completely screwed in Autocad.
    Bruce Gow.
    Architect.
    Revitalize. Blog
    2004-05
    Brisbane
    1,115
    Sounds like the solution would be to rotate the image out of revit then import already rotated. Obvious export bug needing attention me thinks...
    Chris Price
    Xrev Pty Ltd
    Revit Rants BLOG
  1. Exporting from Revit to AutoCAD - layer properties
    By pramodjoseph870122 in forum Revit - Platform
    Last Post: 2012-03-14, 12:44 PM
  2. Exporting Revit to AutoCAD Layer Controls
    By cburch909152 in forum BIM Management - General
    Last Post: 2011-04-25, 04:09 PM
  3. Label Styles - "Tick" exporting on Current Layer not General Layer
    By LeafRider in forum AutoCAD Civil 3D - Alignments
    Last Post: 2011-03-09, 04:34 AM
  4. Difficulty with Layer name when Exporting to CAD
    By dgraue in forum Revit Architecture - General
    Last Post: 2006-05-31, 12:32 AM
  5. Exporting to AutoCAD - Layer Question
    By yzhou in forum Revit Architecture - General
    Last Post: 2005-01-03, 07:33 PM
