Results 1 to 6 of 6
Thread: I have Arched Brick openings and windows and I need the brick hatch to Arch?
    Member billyn's Avatar
    2005-09
    5
    Question I have Arched Brick openings and windows and I need the brick hatch to Arch?
    Can anybody think of a way to get a brick hatch to arch by brick I mean the ends of brick forming a arch around the openings and window heads?
    Thanks for any help!
    100 Club jgardner.79905's Avatar
    2004-12
    153
    Cool Re: I have Arched Brick openings and windows and I need the brick hatch to Arch?
    Below I have place a link to a page in the autodesk site that contains some user made style. The page you will go to with like below is of some window style you will see one here that was made with a brick sill. Check it out and see if a modified version of this window will help, or it might just show you how to make your own.
    The window style is:
    Window Assemblies Styles_132
    The link isCopy and past the link below into your explorer's address bar)
    http://usa.autodesk.com/adsk/servlet...linkID=2475897
    let me know if this helps.
    Jason
    2006-05
    2
    Default Re: I have Arched Brick openings and windows and I need the brick hatch to Arch?
    I don't believe this is possible through convention 2d hatch methods. I have created 3d mass element blocks and used polar array to place to get desired results. If your're using a keystone at top of arch, break up the array for right and left side and use mirror.
    2002-12
    271
    I've not done this but I have pondered whether a customised curtain wall with 3d brick model for the infill might be used. You can curve a CWA but it's displaymight get confused as you turn it on it's side. You would need to use it to create a block to size that get's inserted into the window or door style but in theory in myhead it should work.
    In simple 2D you would need to create a block and array the joints around. I have done this and it's hit & miss to get the spacing.
    2011-05
    926
    Quote Originally Posted by jgardner.79905 View Post
    Jason
    Clicking on your link produced the following result: "The Page You Were Looking for Was Not Found"
    2005-07
    2,356
    Quote Originally Posted by cgraham View Post
    Well the correct link is
    http://usa.autodesk.com/adsk/servlet...linkID=9240658
    Although it is just a style showing a flat brick sill.
  1. 2013: Arched Brick Accent Above Windows
    By building313346197 in forum Revit Architecture - General
    Last Post: 2012-12-21, 04:08 PM
  2. Brick Arch
    By sethridge in forum Revit Architecture - General
    Last Post: 2009-12-16, 08:51 PM
  3. arch brick soldier
    By PHOTOS4ME in forum AutoLISP
    Last Post: 2009-06-09, 01:37 PM
  4. Brick arch?
    By patricks in forum Revit Architecture - Families
    Last Post: 2005-06-16, 09:14 PM
  5. Brick Arch
    By melbs19 in forum Revit Architecture - General
    Last Post: 2003-12-31, 04:54 PM
