Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: LASTSET selection set
  1. #11
    0,0,0 The Origin
    8,570
    Default Re: LASTSET selection set
    Quote Originally Posted by Opie
    But what happens if any third party software has attached data to those entities? This workaround would affect that data.
    Hmm. I suppose there could be occasions when it mattered.
    I've never been in that position though.
  2. #12
    2008-04
    39
    It ought to be expanded to include any entities created with the last command. Not just mirror or copy, but also basics like DTEXT or LINE.
    Currently one can use Select; Last; but it only selects the one most recent line, rather than all lines created in that one command.
    LASTSET is an excellent variation to the SELECT options that would benefit geometry additions greatly.
  3. #13
    2006-08
    In MasterCam this selection set is referred to as "result" and is enormously useful.
  4. #14
    2008-04
    39
    Good call. Though this is an old wish it would still be an excellent addition to the software.
    SELECT;Result;; or COPY;;Result; to automatically include all objects added inside the most recent addition command (as opposed to only the single last object created in that one command).
  5. #15
    Tallahassee, FL USA
    3,658
    irneb posted a very nice lisp for doing this with options.
    http://forums.augi.com/showthread.ph...modification#5
    I've been using it for years.
  6. #16
    5,714
    Thanks for sharing... Off to tinker with resultant AeccDbFeatureLines via CREATEFEATURELINES Command in C3D.
    Separately... Any issues, or suggestions for enhancement? I only ask, as I was already making notes to develop a[nother] .NET Autoloader plug-in.
    Cheers
  7. #17
    Tallahassee, FL USA
    3,658
    Cheers
    His post describes it pretty well. Try it when prompted for selection and you will see options at the command line like "Which one of these do you want to select? 0-OFFSET 1-COPY 2-LINE <0>: 1". It must be autoloaded in each drawing since the selection sets must be created prior in order to use them afterwards. I have a Select Sub-Menu in my Object Snap Cursor Menu and named the 'Result macro "Added by Previous Commands". Not something I use everyday, but great to have when I need it.
  1. Replies: 1
    Last Post: 2015-04-05, 03:26 AM
  2. Replies: 0
    Last Post: 2014-05-09, 11:25 AM
  3. Selection by circle and selection by direction
    Last Post: 2012-06-23, 09:15 PM
  4. Replies: 4
    Last Post: 2010-03-24, 09:19 AM
  5. Help relating to selection and selection sets
    By csgohjmj in forum AutoLISP
    Last Post: 2004-09-17, 03:35 PM
