Results 1 to 10 of 17
Thread: LASTSET selection set
    ACAD Wish List Administration
    2005-06
    1,920
    Default LASTSET selection set
    Summary: A new selection set that selects last set of items created by a copy or mirror command
    Description: Create an additional selection set type "LASTSET" which would contain the new items created by a copy or mirror command.
    How Used: If you copy a group of items to a new location and then want to perform another operation on that new set of items, you have to select them all over again, which sometimes isn't easily done. The "PREVIOUS" selection option will easily select the original set that was copied, but there is no easy way to reselect the NEW set of items. The "LAST" selection option will find only the very last singe item created. This new selection set type would find the full set of entities just created.
    Feature Affinity: Modify
    Submitted By: Mark Terres on October 3, 2005
    2004-07
    2
    Smile Re: LASTSET selection set
    It is very useful
    0,0,0 The Origin
    8,570
    Default Re: LASTSET selection set
    Me too. Yes please.
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    I agree...
    100 Club lcamara's Avatar
    2003-11
    Kaneohe, Hawaii
    130
    Lightbulb Re: LASTSET selection set
    The option could be called "New" or "Newset" (so you could access the option by typing "n") and should select ALL of the new objects from the last command (such as "copy" or "mirror"), whether they are on or off screen (like "Previous" does).
    I would like to pose a question (maybe we should have a poll): What should the behavior be for commands such as copy multiple? Should only the last copy set be selected, or all of the new objects (since the start of the last command)? Personally, I only recall wanting this option when I'm doing a single copy (or mirror), but I was curious how others would use it (for a multiple condition). Maybe there could be a second option for "Multiple new", or just hit the new option twice/multiple times to progressively select the preceding new sets?
    Also, there needs to be an option (similar to undo groups) to programmatically set where the "New" group begins and ends. For example, I have a command that draws a truss (multiple objects from line & pline commands). After running that command, I'd like to be able to select all those objects without having to window it. I could probably achieve similar functionality now (and use the "Previous" selection), but it would be more consistent to be selected through a "new" option.
    2006-01
    This would be extremely useful.
    2006-02
    Agree that it would be extremely helpful.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by acadwishlist
    I had assumed that everyone knew the workaround for this but perhaps I was wrong.
    Anyway - Copy your objects in place ("from" and "to" locations are the same) then start the Move command using the "P"revious selction set. You actually move the original objects and the copies stay at the original location.
    HTH.
    0,0,0 The Origin
    8,570
    The above does not detract from the original wish, though.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by jaberwok
    HTH.
    But what happens if any third party software has attached data to those entities? This workaround would affect that data.
  1. Replies: 1
    Last Post: 2015-04-05, 03:26 AM
  2. Replies: 0
    Last Post: 2014-05-09, 11:25 AM
  3. Selection by circle and selection by direction
    Last Post: 2012-06-23, 09:15 PM
  4. Replies: 4
    Last Post: 2010-03-24, 09:19 AM
  5. Help relating to selection and selection sets
    By csgohjmj in forum AutoLISP
    Last Post: 2004-09-17, 03:35 PM
