Thread: Trying to create a Milgard EtchMatte Pattern for glass.
    2003-09
    California
    400
    Default
    I wanted to get some help in trying to create a pattern for glass. We're going to use a Milgard EtchMatte pattern that's a dots off standard pattern 1/8" hole, 1/4" on center white frit 60% coverage. Here's the only info I could find on milgard's site:
    http://www.milgardtempering.com/html/emportfo.pdf
    or
    http://www.milgardtempering.com/html/etchmatt.html
    If someone could get me going in the right direction, I would really appreciate it.
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Default Re: Trying to create a Milgard EtchMatte Pattern for glass.
    If this is for a rendering then use a bitmap based material using a gif as the bitmap and make the transparent, then only the coloured surfaces will show up in the rendering. If you want to put a photo on the glass then probably the easiest way will be to make a large gif for your material and play with its x/y offsets to suit your rendered image, time consuming but sure to achieve impressive results.
    If it for a 'drawn' view just use a color fill and print colour to a black and white printer you will get a grey shade image which might do the trick. There is a window hatch pattern on RUGI for download.
    2003-09
    California
    400
    PeterJ,
    Thank you for your help. I intend to use it for rendering, so I'll make a bitmap and do as you said. Thank you for your help!
    2003-04
    London, UK
    1,948
    I looked back at what I had previously and in fact I used a tiff file and then set the background to be transparent.
    You can find an explanation of the process here. Apologies for the earlier red herring.
    2003-09
    California
    400
    Thanks for the link. I appreciate it.
  1. Any Suggestions for creating frit pattern on glass
    By mthurnauer in forum Revit Architecture - General
    Last Post: 2013-11-15, 03:11 PM
  2. 2014: Frit Glass not not showing a shadow pattern in render?!?!
    By andrew.arch511 in forum Revit Architecture - General
    Last Post: 2013-10-14, 07:29 PM
  3. Ability to Create a Pattern from a Pattern
    Last Post: 2012-12-14, 04:33 AM
  4. Can I create a new fill pattern?
    By cris_scotti in forum Revit Architecture - General
    Last Post: 2007-02-13, 01:43 PM
  5. howto create a glass wall with a glass door
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2007-01-22, 07:49 PM
