Thread: Extract Blocks from a drawing file
    2005-08
    4
    Default Extract Blocks from a drawing file
    Hi I have created a drawing with about 60 - 70 blocks on that I will use constantly, I normally wblock the blocks to created individual drawings of each block. is there any way that I can do this with one command or do I have to do the Wblock command for every individual block
    thanking you in advance
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,401
    Default Re: Extract Blocks from a drawing file
    If you want individual drawing files of each block, I believe the answer is Yes. If you are using AutoCAD 2005 or up. You can use the Design Center to create a tool palette which would need all of those blocks in a base drawing, like you already have. You could then use the tool palette to insert your blocks into cad.
    2009-03
    Thumbs up Re: Extract Blocks from a drawing file
    thanks a million
    2015-11
    Jo'burg SA
    4,512
    If you're adamant in making them into separate DWG files ... then you can use my code in this thread:
    http://forums.augi.com/showthread.php?t=74579
    The MWBLOCK command is what you're asking for.
    2018-10
    Quote Originally Posted by irneb View Post
    Do you have an updated version which would overwrite any existing file and hardcode the directory instead of a popup box.
  1. Please, help me extract data Dynamic Blocks and Attribute blocks to Excel
    By minhphuong.humg453254 in forum Dynamic Blocks - Technical
    Last Post: 2014-04-17, 08:12 PM
  2. Blocks insert larger in one drawing file than another
    By msanders.85217 in forum AutoCAD General
    Last Post: 2008-12-03, 07:59 PM
  3. Extract attribute value from drawing file.
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2008-06-20, 03:21 PM
  4. Count the number of Blocks in a drawing file
    By ajtrahan in forum AutoCAD Fields
    Last Post: 2006-06-02, 02:52 PM
