Thread: Drawing Issue Sheet Managemet
    2002-11
    4
    Smile Drawing Issue Sheet Managemet
    Hello
    Not sure this is the best forum for this question but here goes anyway.
    Is it possible to interface the revision data of a drawing or number of drawings in the Sheet Set Management System with an Excel Spreadsheet and the exported (interfacing) data remain intelligent ie. when the Sheet Set information is updated the Excel Spreadsheet updates automatically.
    I would to do this for an automated Drawing Register / Issue Spreadsheet Checking procedure.
    Thank you any help offered.
    Pete
    Liverpool, England, UK
    13,656
    Default Re: Drawing Issue Sheet Managemet
    Hi
    Off the top of my head, I would imagine / suggest a "custom" VBA solution would most likely serve best for such a task...
    VBA Forum
    Have a good one, Mike
    2002-11
    4
    Smile Re: Drawing Issue Sheet Managemet
    Thanks Mike
    I try and do this using VBA.
    Cheers
    Pete
  1. Automated Drawing Register/Issue Sheet in Revit?
    By barrie.sharp in forum Revit Architecture - General
    Last Post: 2017-09-07, 01:45 AM
  2. converting multi sheet drawing file into single drawing files
    By harryschoenauer in forum AutoCAD General
    Last Post: 2013-01-23, 07:36 PM
  3. Sheet Issue in PDF file name
    By stephenbrowne in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-05-11, 06:28 PM
  4. Sheet Issue/Revisions
    By ljacobs in forum Revit MEP - General
    Last Post: 2008-07-24, 09:13 PM
  5. Drawing Register / Issue Sheet in Excel
    By de-co1 in forum Software
    Last Post: 2006-12-06, 09:25 AM
