There seems to be a buffer on the amount of windows open in 8.1. I am finding this extremely annoying. Is there a setting I am missing? Are the rest of you also experiencing the same issue.
It becomes increasingly dangerous, when there are other files open such as family files.
It's happened twice now in just 2 days, where I switch to an open family to edit.
Once the error occurs
"An error has occurred while drawing the contents of this window. This window shall be closed."
Revit brings up the dialogue box to chose another view. IN ALL INSTANCES RATHER PRESS CANCEL!!!! If you chose another view Revit will shut down!!! Loosing all work.
It's fine when you get the error in the same file all you have to do is "Close Hidden Widows"
and you can continue working. But still extremely annoying!!!!!!
The shut down problem occurs across open files.
Just a word of warning!
