Results 1 to 8 of 8
Thread: Out of Memory Shutting Down
    100 Club Aquaserpent's Avatar
    174
    Default Out of Memory Shutting Down
    When I try to publish image files like aerials I get "Out of Memory Shutting Down". I am also having problems with .tif files, they will print out using the standard plot command but not through the publish command. Any thoughts?
    13,656
    Question Re: Out of Memory Shutting Down
    Hi
    What is system variable BackGroundPlot set to?
    If not set to 0 (Zero), try setting it to 0 (Zero).
    Have a good one, Mike
    174
    Default Re: Out of Memory Shutting Down
    Quote Originally Posted by Mike.Perry
    Hi
    I am on 2004 and can not find a system variable for BackGroundPlot. Is this a new Variable?
    13,656
    Quote Originally Posted by froose
    I am on 2004 and can not find a system variable for BackGroundPlot. Is this a new?
    Hi
    AutoCAD 2005 and above, sorry about that.
    Below are the obvious thinks to check concerning AutoCAD and computer memory resources...
    ID: TS67513 - Error: Out of memory
    ID: TS18145 - Troubleshoot problems relating to insufficient system resources in Microsoft® Windows
    174
    I don't think memory is really the problem I am operating XP Pro with SP 2, Dual Monitors, Dual 3.2 GHz CPU's, 2.00 GB of RAM and Virtual Memory is set to 2046 MB inital size with a max of 4092 MB. Would you not think this is sufficient?
    13,656
    Red face Re: Out of Memory Shutting Down
    Hi
    Yes I would think such a system sufficient, but what do I really know...
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Hi
    With 6000 + post, you either know a lot or at least know where to find it all.
    174
    Ok I have I believe the 8830 driver problem solved, now I need to know if anyone knows of an issue with aerials and the publish command.
    I just found an interesting piece to the puzzle the system variable XLOADCTL is set to 1 or 2, and remains that way through a successful run on publish. However when trying to plot an aerial and publish crashes XLOADCTL is set to 0.
    UPDATE # 2
    I did a little research in the old Batch plot problems we were having and found a problem with Xreffed aerials, so I detached all aerials from all xrefs, then inserted them into the drawing I am trying to publish from and tried again. No luck the publish command will plot everything but aerials.
  1. HP DesignJet 800 shutting down
    By sblackburn in forum Hardware
    Last Post: 2009-06-16, 07:17 PM
  2. AutoCAD 2006 constantly shutting down
    By kevinc.117928 in forum AutoCAD General
    Last Post: 2007-09-28, 06:13 PM
  3. Shutting off Dynamic Zoom
    By todd.mackay in forum AutoCAD General
    Last Post: 2005-12-05, 03:11 PM
  4. Working with Images - OUT OF MEMORY - Shutting Down
    By ccowgill in forum AutoCAD General
    Last Post: 2005-08-24, 01:26 PM
