Summary: Ability to create more than one multi-sheet DWF when publishing to DWF - without restarting the publish command.
Description: Improve the Publish to DWF capability to have the abilty to create more than one named multi-sheet DWF to increase productivity.
How Used: The way that I can use this capability is by Publishing more than one project and creating different name multi-sheet DWF files. The way that this could be done is in the dialog box for publish. You have an option to create more than one multi-sheet DWF. You then have an area of Sheets to publish for the total number of DWF files that you want to create. That say you want to create 5 DWF Files. You would have 5 different Sheet to Publish areas.
Feature Affinity: DWF
Submitted By: Brad Crouse on October 11, 2005
