Thread: Storm Water Detention Design
    Active Member dlampley.41310's Avatar
    2002-11
    Kentucky
    72
    Default Storm Water Detention Design
    Will Civil 3D do Storm Water Detention Design? If not, what software are you guys using for that?
    2002-11
    Kentucky
    72
    Default Re: Storm Water Detention Design
    Never mind; I've since learned that Civil Series does have a Hydrology component. I also found out that a few of our Civil guys trained on it a couple of years ago and decided that it was too complicated so they're using Eaglepoint and/or Haestead (?) instead. Any thoughts about that?
    P.S. I'm not a civil guy. I'm kind of playing the role of CAD manager and I'm helping some new civil guys evaluate software.
    Thanks!
    2001-05
    Austin, TX USA
    2,201
    Quote Originally Posted by dlampley.41310
    Thanks!
    I have used Ealgepoint to do this type of work. Does a pretty good job. I would suggest you don't leave out Civil 3D in you evaluations. Two years is a long time in the software biz. I wouldn't be surprised if the Hydrology component was completely rewritten. It could be better in the newer version.
  1. CV304-4: Detention Pond Design the Easy Way With Hydraflow Hydrographs
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2020-09-21, 02:35 PM
  2. Replies: 0
    Last Post: 2015-08-07, 05:24 PM
  3. MP318-1: Implementing 3D Design on Water and Wastewater Projects
    By Autodesk University in forum MEP Design and Engineering
    Last Post: 2014-12-01, 03:31 AM
  4. TUTORIAL SOBRE STORM WATER & ANALYSIS
    By cadia in forum AutoCAD Civil 3D - General
    Last Post: 2009-03-16, 07:22 PM
  5. Revit for Water Treatment Plant Design
    By djyr2003 in forum Revit - Platform
    Last Post: 2008-09-29, 10:47 PM
