Thread: Boundary intersects itself. Surface boundary could not be applied.
    Member brian.59027's Avatar
    2003-09
    7
    Default Boundary intersects itself. Surface boundary could not be applied.
    This is the message displayed when I try to define my surface boundary in the Terrain Model Explorer. Is there an alternate solution to redrawing my boundary?
    2001-05
    Austin, TX USA
    2,201
    Default Re: Boundary intersects itself. Surface boundary could not be applied.
    You could try MAP's Drawing Clean Up tool.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    Civil Engineering Moderator MHultgren's Avatar
    Clyde, NC - USA
    1,381
    If you zoom out so that you can see the entire boundary, you should see a green X locating where the boundary is intersecting itself, Zoom into that intersection, break the pline and then all should be well. if you have more than one intersection like this, you will need to repeat as needed to clean up the vertices.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
  1. Replies: 0
    Last Post: 2012-03-29, 05:35 AM
  2. Add Boundary to TIN Surface
    By BlackBox in forum AutoLISP
    Last Post: 2010-10-11, 09:14 PM
  3. crop surface and a boundary
    By eleonard in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-06-29, 11:52 AM
  4. Surface Boundary Issues
    By clarkl in forum AutoCAD Civil 3D - General
    Last Post: 2007-12-11, 03:36 PM
