Results 1 to 9 of 9
Thread: Custom CUI and custom toolbar icons
    2005-02
    54
    Question Custom CUI and custom toolbar icons
    I created a new workspace called "TEST" under "Land" After that I copied "Land" and "test" to a network drive and then I set up my Main & Enterprise. I then went into custom interface and transfer "TEST.cui" to my custom.cui. That went great. But my custom toolbar icons are all jacked.
    So, If a group of us want to create company workspaces and toolbars and have them copied to a network drive, how do we go about doing this without the toolbars changing to clouds ? ????
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,260
    Talking Re: Custom CUI and custom toolbar icons
    Quote Originally Posted by kschultz
    kschultz, I would start by searching help and these forums for enterprise customization files and enterprise cui (respectively).
    (don't forget when using 'search' on the forums, for short words bracket with *'s)
    from help:
    An enterprise CUI file typically stores customization information that is shared by many users but is controlled by a CAD manager. Enterprise CUI files make maintaining and modifying customization data easier for the individual responsible for controlling users’ drawing environments.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    2005-02
    54
    Question Re: Custom CUI and custom toolbar icons
    ok, no good.
    I changed all paths back to "Standard". Now my icons are back. Is there any threads out there about how to create custom toolbars and have them be used my others and you can transfer into new releases of autoCAD?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Default Re: Custom CUI and custom toolbar icons
    ok, no good.
    Since toolbars are part of the CUI now you would need to share your cui and also have the icon bmp files in a place others have also pathed to in the support folders for AutoCAD.
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    Did you copy the resource dll when you copied the cui files up to the network?
    2005-02
    54
    No I didn't copy the Land.dll file. Didn't know I had to copy it also.
    If a group of us set up all the custom toolbars and workspaces, what files do we need to copy over to a read only drive????
    100 Club mcoffman's Avatar
    2005-08
    Porland, OR
    127
    You need to make sure that you're bmp button image files are located on the same (or another accessible) network location as your cui file. Then you need to go into your support file search path and add a path to that location so AutoCAD knows where to look for your images. A quick question for you, do your toolbars have all their functionality? If they do then this should resolve your problem, else something else may be going on...
    MC
    2005-02
    54
    Yes my toolbars have their functionality.
    Question for any one. After we create our custom toolbars and copy them to a network drive and set up paths, will our toolbar icons change to clouds&question marks?
    2002-01
    jUSt Here (a lot)
    6,836
    They should only turn to those icons if the correct icons are not found within the support paths.
  1. Custom Icons
    By Spenner in forum CAD Management - General
    Last Post: 2011-03-31, 03:09 PM
  2. Custom icons disappeared
    By ralph.burkey in forum AutoCAD CUI Menus
    Last Post: 2009-11-17, 12:04 AM
  3. Replies: 5
    Last Post: 2009-03-05, 10:12 PM
  4. Toolbar images not being successfully applied to custom toolbar
    By tbrown.113150 in forum AutoCAD CUI Menus
    Last Post: 2007-04-06, 05:06 PM
  5. Custom Toolbar icons show as ? marks
    By tony.nichols in forum AutoCAD CUI Menus
    Last Post: 2006-01-23, 03:03 AM
