Results 1 to 9 of 9
Thread: Express Tools command PLJOIN gone in AutoCAD 2006?
    2001-08
    13
    Unhappy Express Tools command PLJOIN gone in AutoCAD 2006?
    Does anyone know where the Polyline Join command went in AutoCAD 2006? Thanks!
    0,0,0 The Origin
    8,028
    Default Re: Express Tools command PLJOIN gone in AutoCAD 2006?
    Look at the newer options in Pedit. Multiple and Fuzz were added there.
    PLJoin is, I believe, no more.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    Member mckishen's Avatar
    2001-04
    13
    why is it gone? pljoin was such a great command, but I don't think it's worked since R2000i. using pedit requires more keyboard entries as opposed pljoin using a shortcut key assigned to the command followed by a quick crossing window and a thumbsnap to the spacebar to sum things up... three moves and bam, you were done. using pedit requires around eight entries to complete the same operation.
    2001-04
    13
    okay, seven moves after toggling peditaccept =)
    2001-03
    13,499
    Hi
    Try searching the forums using the following search criteria -
    Key Word(s): PlJoin
    RE: pljoin command
    ID: TS64921 - Availability of AutoCAD® Express Tools for AutoCAD® 2002 software
    Have a good one, Mike
    Member jprine's Avatar
    2003-10
    Monett Missouri
    9
    We have had the same question asked at my company.
    I ended up stealing the lisp files required from an Express tools and it works great.
    There shouldn't be a problem doing that correct?
    2001-03
    13,499
    Quote Originally Posted by jprine
    Hi
    If you following link "pljoin command" from above post, you will see that is one of the solutions offered.
    Last edited by Mike.Perry; 2005-11-04 at 08:05 AM. Reason: Correct my poor grammar.
    2003-12
    Santo Domingo, Dominican Republic
    29
    You can use the new join command to join Polylines that are connected at each other's end points. It doesn't work with lines, though; but if you have one polyline with other types of objects connected to it, lines or arcs, you can pick the polyline first and then the rest of the objects.
    Dynamic Blockhead Mod Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Quote Originally Posted by huascarfdez
    yup. this is what I do and it works fine for me. JOIN in a great little tool.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
  1. Replies: 2
    Last Post: 2007-02-01, 07:52 PM
  2. Express Tools menu does not show up in AutoCAD 2006
    By sampsonpatricia in forum AutoCAD General
    Last Post: 2006-06-13, 08:51 PM
  3. Getting Express tools to work with AutoCAD 2006
    By clovis in forum AutoCAD General
    Last Post: 2006-05-24, 11:42 AM
  4. Where are the Express Tools (AutoCAD 2006)
    By del.wingerter in forum AutoCAD General
    Last Post: 2006-01-25, 07:00 PM
  5. Express Tools command PLJOIN in AutoCAD 2005
    By kgray.65984 in forum AutoCAD General
    Last Post: 2004-10-18, 06:24 PM
