Results 1 to 10 of 11
Thread: ADA compliant railing styles!
    Member psmith.73426's Avatar
    2004-08
    9
    Exclamation ADA compliant railing styles!
    Why is it that Autodesk can program that can do just about everything other than a simple wall mounted pipe rail that is 1 1/2" dia. and has a 1 1/2" clearance to the wall that it is mounted to. For crying out loud, could it be any simpler? While I am on my rant, how about better documentation of "How to edit an existing railing styles profile".
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Default Re: ADA compliant railing styles!
    So should I add this to the list of Families we would like to have?
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2004-08
    9
    Absolutely! Something as simple as this should not give the programmers too much heartburn to refine.
    Thanks.
    2003-04
    Chino, CA
    4,743
    Coming....I saw a Power Point yesterday that might become avaialable.
    Did you see the Handrail extensions that are availabe in the Web Library? There is a 1 1/2" dia, 1 1/2" offset from the wall pipe handrail component.....
    There is also on the Web Library, a "railing Sample" file and a "Stair Sample" file from which you can cut and paste stairs/handrail types into your project and use. Attached is an example of a stair with a wall mounted pipe handrail.
    Scott D Davis
    Autodesk, Inc.
    2004-08
    9
    Smile Re: ADA compliant railing styles!
    Thanks for the reply Scott,
    However, how can I use Revit information in ADT '06?
    It would be nice to have the ability to eidt railing styles easily in ADT.
    Pete
    2002-09
    Madison, WI
    4,439
    I'd like to get the ability to have a bullnose tread as well, but I haven't found the option yet. If ADT can do stairs to code (or at least I thought it was supposed to) it should be able to follow them. They aren't that difficult.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2003-04
    Chino, CA
    4,743
    Oh shoot! I'm sorry guys, I didn't realize I was answering in a ADT forum!!!
    Scott D Davis
    Autodesk, Inc.
    2005-07
    2,354
    Quote Originally Posted by david_peterson
    Hi David do you mean for the first tread to have a bullnose to it? Not sure whether this is what you mean but check out a thread where Steve Bennet answered with this:
    Sorry not sure how to link to other threads.....
    RE: Stairs
    You mean like what I have in the attached file? It's a simple edge customization projection. Just pick the stair, right click, Edge, Project & project it to a polyline representing your curve.
    __________________
    Steve Bennett - BSD, AE
    L.A. CAD
    >Check out my ATP course on Door/Window Assemblies!<
    2002-09
    Madison, WI
    4,439
    Nope, I'm talking about the ability to show a true bull nose edge on every tread as you would typically see in any nice wood stair.
    I saw Steve's post, I thought that only applied to the first step. But then again, wouldn't a check box be nicer that doing all that modifying? I guess I'd also like to be able to choose the profile for the stringers while I'm at it.
    Dave Peterson
    2004-08
    9
    Guys,
    This is fun to have you talk about bullnose styles on stairs, however there are stiil no answers to my original question.
  1. Code compliant stair railing extensions
    By louissierra in forum Revit Architecture - General
    Last Post: 2008-04-11, 05:56 PM
  2. Railing Styles
    By arcadia_x27 in forum ACA General
    Last Post: 2005-12-09, 01:12 PM
  3. ADT - ADA compliant?
    By michaelz in forum ACA General
    Last Post: 2004-08-24, 05:11 PM
  4. railing styles
    By nbeach in forum Style Management
    Last Post: 2004-06-14, 09:33 PM
