Thread: AutoCAD Mechanical Blocks
    2004-11
    Pittsburgh, PA
    4
    Default AutoCAD Mechanical Blocks
    Hello:
    I am in need of an efficient software package that provides accurate mechanical blocks.
    ie. 2D pipe sizes (all sizes), valves (all types and sizes), PVC, ductile iron, butt weld etc.
    Does anyone know of a product I can find on the web that works well and can be used by
    the entire office (licensing)
    Any help is much appreciated.
    Jason Coppula
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,285
    Question Re: AutoCAD Mechanical Blocks
    Quote Originally Posted by jason.coppula
    Hello:
    Jason Coppula
    are you looking at a program to create new blocks, or at just a block library with all of these things already in it?
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    2001-03
    13,499
    Default Re: AutoCAD Mechanical Blocks
    Hi
    Good manufacturing companies of such items normally supply free AutoCAD Block Libraries; plus the better ones also supply free AutoCAD Partial Menu's that Insert (amongst other stuff) these Block Libraries (this is true for UK based companies).
    Have a good one, Mike
    2004-11
    Pittsburgh, PA
    4
    I am looking for a block library.
    2001-12
    St. Louis
    4,285
    Talking Re: AutoCAD Mechanical Blocks
    Alright, I'll move this from the Software forum to this one as I believe it would be better served here.
    As Mike suggested, you might want to check with some manufacturer's, but, you can also just start looking for sites that offer blocks as listed in this post.
    Technical Editor
  1. Diferenças entre o Autocad 2009 e o Autocad 2009 Mechanical, Mechanical desktop?
    By icavalheiro67 in forum Português - Inventor / AutoCAD Mechanical / AutoCAD Electrical
    Last Post: 2009-10-14, 12:15 AM
  2. AutoCAD Mechanical e Mechanical Desktop
    By cnsilva in forum Português - Inventor / AutoCAD Mechanical / AutoCAD Electrical
    Last Post: 2008-03-16, 06:05 AM
  3. mechanical pipe blocks
    By eleonard in forum AutoCAD General
    Last Post: 2006-04-26, 12:50 PM
  4. autocad 2000 lt drawing wont open in autocad mechanical 2005
    By garryh in forum AutoCAD Mechanical - General
    Last Post: 2005-06-21, 10:02 PM
  5. Mechanical Desktop&Autocad Mechanical
    By danang_061 in forum MDT - General
    Last Post: 2004-10-29, 05:34 AM
