Thread: Inserting Different Visability States
    Member matt.bellenoit's Avatar
    2002-03
    Northampton
    32
    Default Inserting Different Visability States
    Hi I have a Dynamic Block called "A"... in it i have options "B", "C", "D", etc... can you create a tool bar button to insert the block using the option you want? I already created a tool palette and created the different options as individual tools, but I would also like to create a flyout toolbar that does the same thing (some of my user's are VERY anti-tool palettes)...
    eg...
    button for -insert, "A", using Visability "B"...
    button for -insert, "A", using Visability "C"...
    etc...
    Thanks for any input...
    noit
    matt.bellenoit@bbraun.com
    p.s. I'm not a LISP guru, so if thats the only way to do it I'm in trouble!! LOL
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,226
    Default Re: Inserting Different Visability States
    Place the block into a drawing multiple times with each item being a different visibility setting. Then drag each item onto the toolbar. They should be able to drag back onto the drawing with the visibility setting intact.
    HTH
    Brad
    Brad Novak
    Director of Information Technology
    Gp GOETTSCH PARTNERS
    Chicago, IL
    2002-03
    Northampton
    32
    I don't want them to create a tool palette button, I want a toolbar button... I was going to create a flyout toolbar containing each instance... I already have the tool Palette set up...
    Thanks though...
    noit
    2003-11
    Chicago
    1,226
    Oops, sorry. I even said toolbar.
    DOH!
    Brad Novak
    Chicago, IL
  1. Layer States to Visibility States?
    By Ant59 in forum AutoCAD General
    Last Post: 2009-07-07, 11:17 AM
  2. need help with visability
    By cookie in forum Revit MEP - General
    Last Post: 2009-03-02, 09:38 PM
  3. 2 visability states one block? is it possible
    By Gigliano70 in forum Dynamic Blocks - Technical
    Last Post: 2008-05-19, 02:56 PM
  4. Replies: 9
    Last Post: 2007-03-15, 07:34 PM
  5. Layer states - can we save the states out ?
    By Chirag Mistry in forum AutoCAD General
    Last Post: 2005-04-01, 04:36 PM
