Results 1 to 10 of 13
Thread: text format and non printing cells in tables
    13
    Question text format and non printing cells in tables
    I have a problem with the way autocad "thinks"
    I import a table, set the text height to 7" and all my text has a height modifier of .7716x in the text line making them all about 5 3/8" height
    how do I control this instead of going through hundereds of cells and deleting the height modifier. I have tried match cells, match prop.... match stick (j/k).
    also I have some text cells that are not printing, I can copy in info from another cell to ficx this. but I would rather keep it from happening in the first place.
    thank you all
    Jason
    13
    Default Re: text format and non printing cells in tables
    not even one reply in two weeks?
    2001-03
    13,499
    Hi
    Please post an example drawing file that exhibits the behaviour you describe above, so we can take a look at the problem / issue first-hand.
    Have a good one, Mike
    13
    Here is a simple table from excel and pasted into autocad
    2003-03
    Alberta
    248
    Given the test file I seen no problems with either file. None of the cells are being missed when plotting. I tried copy-paste from your excel file, everything seemed to work fine. Every cell with text had the correct data. I even tried to change the sizes of text, again no problems. Not sure what's happening at your end.
    Benjamin
    CAD Manager
    Meggitt Defence System Canada
    13
    Look at the properties of the text. it has a height modifier of.7716x, reducing its overall height. I would like to forgo having to change EACH CELL. just to fix the height.
    100 Club MikeM4OSU's Avatar
    2004-02
    Tulsa, Oklahoma
    195
    Try changing your table style to have the same fonts style name as your excel file. Be sure that your font type is set within the font style name and then import your table. Not sure if this will fix your problem but it is a difference that I see. Let me know how it comes out.
    2001-03
    13,499
    Hi
    Take a look at the "Text Height" value specified within the OLEScale dialog box ( plus, if using AutoCAD 2006 take a look at the OLETextSize command ).
    I believe you will find the "Text Height" value set there, has a major affect ( relationship ) on the Text Height you see in your AutoCAD Table ( when Imported via Excel data ).
    For what it is worth, I also do not experience any printing issues with contents of Cells missing from Plotted output ( as reported by Benjamin above ).
    13
    Quote Originally Posted by mikem.65918
    ill try that one out, thanks
    13
    I cant access the dialog without an ole object. so I would have to import it, and then change it. but these are not ole objects, they are tables.
  1. Blank cells within tables
    By b.boyes in forum AutoCAD General
    Last Post: 2007-06-20, 05:07 PM
  2. Link 2 cells in different Tables
    By rgorman in forum AutoCAD Tables
    Last Post: 2007-01-08, 05:48 PM
  3. Replies: 5
    Last Post: 2006-03-13, 06:27 PM
