Thread: Improvements to SSM
    ACAD Wish List Administration
    2005-06
    1,920
    Default Improvements to SSM
    Summary: For the width of the column for the property name to be saved if it is changed (within the properties dialog box of a sheet in sheet set manager).
    Description: In the properties dialog box of a sheet in sheet set manager the width of the column for the property name can be changed but is not saved if repoened. I wish the width was retained.
    How Used: Ease of use.
    Feature Affinity: Other
    Submitted By: Jimmy Bergmark on October 19, 2005
    13,656
    Question Re: Improvements to SSM
    Hi Jimmy
    Just for my own reference (so I can understand), is this Wish list item the same as Freddy's...
    Define width of columns in sheet list table
    Mike
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: Improvements to SSM
    Quote Originally Posted by Mike.Perry
    Hi Jimmy
    Mike
    I don't think so. See my response in the other wish.
    They are not the same
    Hi Jimmy
    Mike
    13,656
    Thumbs up Re: Improvements to SSM
    Quote Originally Posted by jimmy.bergmark
    Hi Jimmy
    Thanks for confirming...
    RE: Define width of columns in sheet list table
    Mike
  1. PDF improvements
    By peter.trezise in forum AutoCAD Mechanical - Wish List
    Last Post: 2008-10-01, 01:27 AM
  2. Improvements to CUI
    Last Post: 2005-09-30, 02:48 PM
  3. 8.0/N - Schedule Improvements - O
    By janunson in forum Revit Architecture - Wish List
    Last Post: 2005-07-14, 07:04 PM
  4. Roof Improvements
    By snurresprett9 in forum Revit Architecture - Wish List
    Last Post: 2005-03-28, 11:49 AM
