Results 1 to 6 of 6
Thread: Don't list XREF Layers when they can't be selected
    ACAD Wish List Administration
    2005-06
    1,921
    0 Did you find this post helpful? Yes
    Default Don't list XREF Layers when they can't be selected
    Summary: Not listing layers where they cannot be selected.
    Description: Don't list xref layers in places where they don't belong (and can't be selected) like the Properites Window Layer droplist.
    How Used: I would be able to find "native" layers without having to look through non-pickable xref layers.
    Feature Affinity: Object Properties Manager
    Submitted By: Josh Crawford on October 20, 2005
    2001-11
    2
    Default Re: Don't list XREF Layers when they can't be selected
    This is already manageable in the Object Properties Manager.
    Select the "xref" filter (listed as one of the filters whenever an xref is present), then check the Invert Selection checkbox and the Apply to Layers Toolbar checkbox. Now only the base layers for this drawing will be visible in the Layers drop-down.
    2011-08
    4,592
    Exclamation Re: Don't list XREF Layers when they can't be selected
    Product and Feature: AutoCAD - Object Properties Manager
    Submitted By: Josh Crawford on Wed, 13 Jun 2012
    2002-10
    3
    Not sure what version of AutoCAD you are using where this is available. However, in C3D 2013 what you proposed does not work. The Object Properties Palette's Layer droplist does not respond to the Apply to Layers Toolbar. As the name suggests, Apply to Layers Toolbar means just (and only) that.
    Quote Originally Posted by mike.grutter View Post
    2007-07
    3
    I think they could add a toggle in the xref table that could accomplish this.
    Programming Moderator BlackBox's Avatar
    2009-11
    3,389
    This functionality has been incorporated into AutoCAD 2014 products... From this article:
    XREF enhancements
    XREF also has some little enhancements.
    In previous version, you can see XREF layers and linetype in the dropdown list like below.
    In AutoCAD 2014, this list simplified as below:
    • Linetype in referenced files will not show in ribbon dropdown list. But still appear in linetype manager and properties palette.
    • Layers will not show in properties palette dropdown. But still appear in ribbon dropdown and layer properties palette.
    "Potential has a shelf life." - Margaret Atwood
    Autodesk Exchange Apps
    ~ Autoloader ~ AutoCAD Security
  1. 2008 SCALE 1:100 xref xref xref xref- scale list issues
    By Apsis0215 in forum AutoCAD Customization
    Last Post: 2008-11-21, 07:17 PM
  2. Layers that are Visible, but cannot be Selected or Snapped To
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2008-07-01, 08:18 PM
  3. Replies: 2
    Last Post: 2007-06-12, 12:20 PM
  4. AutoCAD LT 2007 - List Xref Layers by picking them
    By kwong in forum AutoCAD LT - General
    Last Post: 2007-04-30, 12:13 PM
  5. Replies: 3
    Last Post: 2006-09-22, 08:22 PM
