Summary: The ability to copy a block and rename it.
Description: To the ability to copy block and give it different name.
How Used: I would use this ability to copy a block in a drawing and give it a different name. Example: Lets say that you have a fypon head feature for a window or door. You want to Change the appearance of that block. But you don’t want to add it to the library. So you would select copy block and give it a different name. Now you have a child block that is from the parent block. Everything is still the same as the parent block except for the name. Now you can do a block edit and alter that block to show it the way you want it.
Feature Affinity: Blocks
Submitted By: Brad Crouse on October 26, 2005
