Hi
I am using AutoCAD 2000i and when I try the Tframe command I get the error message ' Fatal Error : Unhandled Access Violation'
Can anyone help?
Neil
Hi
Can anyone help?
Neil
Hi NeilOriginally Posted by neilcheshire
Just a heads-up...
Please note I have edited the thread title.
I believe the command is TFrames and not TFrame.
Thanks, Mike
Forum Moderator
HiOriginally Posted by neilcheshire
Does this occur in ALL drawing files or just the odd one or two ?
What happens if you use the command _.ImageFrame or Wipeout ( with "Frame" option ) ?
Have a good one, Mike
Mike
Just tried the command in a separate drawing it works okay.
The drawing that I was trying it in was one where I had a drawing template in paper space.
I then pasted an image into the drawing (using copy and paste) from a separate pdf drawing.
I m using the paste special command and then image entity.
Does this help??
Neil
Mike
Just tried it again and it seems to work. Dont know why.
Thanks for your help anyway.
Neil
