Thread: hold text fromatting thru table update
    2005-10
    19
    Default hold text fromatting thru table update
    Hi,
    We just upgraded to 2006 from 2002...Lots to learn.
    I have set up a table style to use when I create schedules from attribute extraction. However, the formatting controls available in the table style dialog box are rather limited. I prefer to center justify certain columns in my schedules, but left-justifty "description" and "comments" fields, e.g.
    If I do this formatting manually, (right click on the selected columns>cell alignment) then update my table, my changes are re-formatted as per the current table style. Is there any way around this? Are there ways to set up a more detailed table template with regard to styles?
    Also, How do you activate the little ballon that alerts you to the need for table updates? Semms I turned it off.
    Great forum, BTW. Just discovered it.
    rob duprey
    2001-03
    13,499
    Default Re: hold text fromatting thru table update
    Quote Originally Posted by rduprey
    Hi
    First guess, system variable TrayNotify
    Someone with AutoCAD 2006 will hopefully address /answer you main question, as I do know Tables were improved on from AutoCAD 2005 ( version I have in front of me ).
    Have a good one, Mike
    Last edited by Mike.Perry; 2005-11-01 at 10:47 AM. Reason: Correct my poor grammar.
    2005-10
    19
    thanks, mike. sorry 'bout those typos...
  1. Not able to update a table in VBA Access code
    By maruvoor.arasi in forum VBA/COM Interop
    Last Post: 2009-04-16, 09:34 PM
  2. Update Style Table
    By jmcshane in forum AutoLISP
    Last Post: 2007-03-06, 01:10 PM
  3. Replies: 1
    Last Post: 2006-12-12, 06:36 AM
  4. Schedule table isn't update ?
    By luongngocthi in forum ACA General
    Last Post: 2006-05-10, 08:39 PM
