Results 1 to 10 of 16
Thread: faster start up
    2003-07
    22
    Cool faster start up
    I was at an autocad user group meeting a few months ago and someone mentioned how to get Autocad's logo not to come up - This for some reason takes a while. I wrote it down but now that I am actually using 2006 I don't understand what I wrote. Does anybody out there know what I am talking about? or have an idea on how to make autocad load faster?
    Dawn
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: faster start up
    Try placing /nologo into your shortcut.
    13,656
    Hi
    Just to offer a little more info on this subject...
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS66634 - Add startup switch
    ID: TS22957 - Startup switches
    Have a good one, Mike
    2004-07
    Detroit Michigan
    2,508
    Getting rid of the logo helps. For someone that does the bulk of their work in AutoCad I would also suggest never closing the program. I leave AutoCad up and running at all times.
    AutoCad could almost be a desktop replacement for me
    2001-12
    St. Louis
    5,407
    Talking Re: faster start up
    Quote Originally Posted by rhall.72202
    ~nods~ I second that... I start it up first thing in the morning and leave it up even when I'm not using it.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Member VirtualBuilding's Avatar
    2005-09
    Kansas City
    47
    Cool Re: faster start up
    You can also use a higher Prefetch in XP, which tells the operating system to save more of the memory settings used to access AutoCAD. I've got mine set so that even after a reboot I can access AutoCAD in less than a 2 count.
    2001-12
    St. Louis
    5,407
    Quote Originally Posted by drolfe.95337
    I'm not quite following you here, could you explain how you do this? (use small words, I'm slow... thx)
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2005-09
    Kansas City
    47
    Computers do what you tell them to do, when you tell them to do it.
    If you want to start a program, you double-click the icon and the program loads.
    To help speed up the process, Windows XP tries to predict what you want before you want it.
    Using its prefetch capabilities, Windows XP tries to load the programs you need before you need them.
    First things first, is your XP using the Prefetch folder C:\windows\prefetch?
    It's kind of like a Temp folder and sometimes will need to be cleaned out to make things faster...
    If this folder is empty then your Prefetch is turned off.
    This is when it gets tricky as it involves editing the registry.. .not recommended for everyone..
    To change the registry settings for prefetching, start the Registry Editor by selecting Run from the Start menu, typing regedit in the Open text box, and clicking OK. When the Registry Editor window opens, navigate through the left pane until you get to this hive:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters
    2004-07
    Detroit Michigan
    2,508
    Prefetch is a good point..........however, in most office settings unless the user has
    admin rights, nothing can be changed. The IT department here has no knowledge of the
    prefetch folder and strongly urges leaving the registry alone.
    Being a computer tech guru in this day and age, I just sit here dreaming of Admin rights.
    2005-09
    Kansas City
    47
    Good point, I often forget that not all the experts work in the IT Department
    However I would encourage people to take these kinds of issues TO their IT department and at least ask them to investigate the possibility that it might make things more efficient and thus more profitable. You might offer them beer and/or food as a bribe, they typically like that =)
  1. There has got to be a faster way
    By A_LOTA_NOTA in forum Dot Net API
    Last Post: 2009-01-14, 05:01 AM
  2. Faster AutoCAD on WAN
    By jaberwok in forum Networks
    Last Post: 2008-04-17, 08:44 PM
  3. Make Autocad start up a little faster.
    By Glenn Pope in forum AutoCAD Tips & Tricks
    Last Post: 2006-06-07, 12:32 PM
  4. Faster Plotting
    By Steve_Stafford in forum Revit Architecture - Wish List
    Last Post: 2004-06-24, 03:55 PM
  5. Making Revit Start faster
    By Scott D Davis in forum Revit Architecture - Tips & Tricks
    Last Post: 2003-06-02, 10:51 AM
