Topic Reference
Jon Giebelerwrote :-
It may be poor practice, but I often start my model in a single workset and then move elements as the project matures. I am at that point and am having problems. If I create a 3d view and display only the roof, when I select everything in the view and try to change the workset to "Roofs" I get an error saying that I must reload the worksets. After I reload the worksets I get the same error. The error doesn't seem to be consistent becasue only a few objects produce it. Example - I had two cupolas, one moved w/out a problem the other will not move. Same with typical roofs.
What am I missing? I need to set these worksets up to manage help with performance.
If I cut the object to the clip board and then paste align them to the smae place (with the proper workset active) the objects will move, but this wouldn't work for objects that I want to keep locked or related to other other items
and LMSmith
(Autodesk Revit Staff) replied:-
This does look like a bug in borrowing - good catch. One work around I found that seems to work is the following: Save To Central and relinquish everything. Then check out the whole workset where the roof elements currently reside. Now you should be able to change them to your roof workset without the Reload Latest error
