Results 1 to 10 of 10
Thread: Publish layout tabs and layout tab names to PDF
    100 Club dfuehrer's Avatar
    2004-11
    130
    Question Publish layout tabs and layout tab names to PDF
    Hello everyone,
    I have a question regarding the publish feature in AutoCAD. I hope that I am posting this in the correct forum.
    We are trying to publish multiple layout tabs to PDF, and have the individual files created have the names of the layout tabs appended to the file name (for project archival, and retrieval).
    It seems to function correctly on AutoCAD 2004, but doesn't work in AutoCAD 2005. Any ideas out there?
    Thanks in advance,
    Don
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: Publish layout tabs and layout tab names to PDF
    How do you have your plot stamp set up?
    2004-11
    130
    I don't believe that we are using the plot stamp feature. Should we be?
    2002-01
    jUSt Here (a lot)
    9,103
    Quote Originally Posted by dfuehrer
    Then how is it working in 2004?
    Using the Plot Stamp would work. You could also use fields with a link to the layout name. I think that is available in 2005.
    2004-11
    130
    OK thanks! I'll pass it on. In case you can't tell, I am asking this for one of my co-workers. I myself don't use the publish feature, however I would like to use it for DWFs. maybe someday...
    Thanks!
    Don
    2002-01
    jUSt Here (a lot)
    9,103
    Thanks!
    Don
    It's pretty good. I don't use it regularly, but I'm starting to use it more.
    2001-05
    Austin, TX USA
    2,201
    Are you using this in conjunction with the sheet set manager?
    13,656
    Hi Don
    Please note I have *moved* this thread from the AutoCAD Sheet Set Manager forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    The following thread, explains why...
    Plot to File- Standard file navigation dialog box
    Have a good one, Mike
    2004-11
    130
    So am I to gather from reading the previous thread, that Autodesk broke this feature intentionally? Something to do with them wanting to support DWF rather than PDF?
    Don
  1. Layout tabs names change when layout renamed in SSM
    Last Post: 2013-01-20, 05:07 AM
  2. 2009: Publish Layout tabs
    By nguyenvanhiep03051984826546 in forum AutoCAD General
    Last Post: 2012-09-20, 03:33 PM
  3. Plot All Layout Tabs Without Using Publish
    Last Post: 2009-02-01, 08:57 PM
  4. Publish selected layout tabs from a single DWG file
    By dzatto in forum AutoCAD Tips & Tricks
    Last Post: 2007-01-03, 02:38 PM
