Thread: Construction Lines Tip
    2005-07
    2,356
    Default Construction Lines Tip
    Forgive me if everyone else already knows this (I can be slow sometimes).
    If you use the construction line from the shapes toolbar you can automatically find edges of walls. eg, if you have a cavity wall say brick/cavity/insulation/block, when putting in a construction line it automatically snaps to the edge of each component (or you can use dynamic input to offset from an edge). This allows you to then trim to an edge rather that to the base line of the wall.
    This works on curved walls as well as straight.
    Also its quite nice that the construction line automatically gets put on a layer that doesn't plot.
    Steve
    Time Lord Steve_Bennett's Avatar
    far, far, far away...
    4,730
    Default Re: Construction Lines Tip
    That's cool. I'll have to see if this is specific to 2006 or not. There will soon be a place for this type of thread too! Stay tuned for more!
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
  1. Construction Limit Lines
    By Arkman in forum Revit Architecture - General
    Last Post: 2023-01-12, 12:48 PM
  2. construction lines
    By ray salmon in forum Revit Architecture - General
    Last Post: 2009-03-05, 07:54 PM
  3. Construction Lines
    By the_cad_monkey in forum Revit MEP - Families
    Last Post: 2008-07-24, 08:15 PM
  4. Construction lines tool?
    By rudolfesterhuyse in forum Revit Architecture - General
    Last Post: 2006-11-15, 07:01 AM
  5. Defpoint Lines / Construction Lines / No Plot lines
    By ykang in forum Revit Architecture - General
    Last Post: 2006-11-14, 10:30 PM
