Results 1 to 9 of 9
Thread: Spaces
    2005-03
    Derby, UK
    194
    Default Spaces
    Can spaces have vaulted ceilings? If so how do you create these?
    Thanks.
    Default Re: Spaces
    Unfortunately not. It's a good thing to wish for. I've run into the same need.
    Administrator richard.binning's Avatar
    2015-12
    In the foothills of the appalachians
    2,261
    Default Re: Spaces
    Is this for modeling purposes or for reporting in a schedule? We found the need to have a ceiling condition called "open to above". We simply applied an override to the property in the schedule.
    RLB
    2005-03
    Derby, UK
    194
    Default Re: Spaces
    I was hoping to be able to report on volumes for rooms without flat ceilings. Think I will post it in the wish list.
    Thanks
    2015-12
    2,261
    Default Re: Spaces
    Ahhh, so you'll have to construct the volume by measuring the entities involved then. Since you could use slabs to represent the vaulted condition of the ceiling, you might grab the area from the space and then calculate the volume as the sum of space volume plus the calculated triangular region above.
    RLB
    Moderator arcadia_x27's Avatar
    2015-10
    The 'Mill,Moncton, NB, Canada
    516
    Default Re: Spaces
    Would it not also be possible to use a Mass element for this situation, and just report the Mass element's volume?
    2015-12
    2,261
    Default Re: Spaces
    Yeah I thought about that too! Only problem is that is just one more thing to coordinate when changes occur.
    RLB
    2005-03
    Derby, UK
    194
    Default Re: Spaces
    I'm coming around to the idea that I will need to use slabs or mass elements, although I'm a bit disappointed that spaces do not have this functionality, as it will make scheduling the space volumes more complicated.
    If I use slabs over mass elements why would there be one less thing to coordinate when changes are made? The slab would not resize automatically would it?
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Unhappy Re: Spaces
    Quote Originally Posted by gdaniels
    Your slab won't resize automatically, but you can regenerate space objects. This really is just one of those limitations of ADT.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
  1. Spaces to cope with vertically irregular spaces better
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2015-12-05, 08:10 PM
  2. 2010: Spaces
    By Heather_W in forum ACA General
    Last Post: 2014-01-02, 04:21 PM
  3. 2012: MEP Spaces
    By RobDraw in forum Revit MEP - General
    Last Post: 2012-07-26, 06:53 PM
  4. Spaces
    By dzatto in forum ACA General
    Last Post: 2007-10-23, 11:28 PM
  5. Spaces
    By pangell in forum ACA General
    Last Post: 2005-12-22, 03:19 PM
