Search the Community
Ask, Learn and Solve
The AUGI forums are an online community where AUGI members
can discuss what they use everyday,
Autodesk Design Software!
  • Thread Tools
  • Display
    2003-12
    18
    Cool Create MTEXT with Lisp
    I am trying to create MTEXT using “entmake” in my lisp routine. The routine is list below, please look at this routine and please point me in the right direction.
    Thank you
     (defun C:PARKING ()
      (setq |CMDECHO| (getvar "cmdecho"))
      (setvar "cmdecho" 0)
      (setvar "osmode" 512)
      (setq PT1 (getpoint "Select mid point of text: "))
      (setq PT2 (getpoint "\nSelect direction of text: "))
    ;;;Text data
      (setq TAG (strcat "ASPHALT PARKING LOT" ))
      (setq ang (angle PT1 PT2))
      ;;;TEXT TO PRINT ON SCREEN
      (entmake (list
    	     (cons 0 "MTEXT")
    ;;;	     (cons 100 "ACDDMTEXT")
    	     (cons 7 "LEROY")
    	     (cons 8 "E_TEXT_L080")
    	     (cons 71 2)
    	     (cons 72 5)
    	     (cons 73 1)
    	     (cons 10 PT1)
    	     (cons 50 ANG)
    	     (cons 41 19.35)
    	     (cons 40 (* (getvar "dimscale") 0.08))
    	     (cons 1 (princ TAG))
      (setvar "osmode" 0)
      (setvar "cmdecho" 1)
      (redraw)
      (princ)
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    2005-05
    Pietari, Venäjä
    1,269
    Default Re: Create MTEXT with Lisp
    Hi jjacoby
    Try this one:
    (defun C:PARKING ()
      (setq PT2 (getpoint pt1 "\nSelect direction of text: "))
    ;;;Text data
      (entmake (list
    	     (cons 0 "MTEXT")
    	     (cons 100 "AcDbEntity")
    	     (cons 100 "AcDbMText")
    	     (cons 7 "LEROY")
    	     (cons 71 5)
    	     (cons 72 5)
    	     (cons 73 1)
    	     (cons 10 PT1)
    	     (cons 11 (list 1.0 0.0 0.0))
    	     (cons 50 ANG)
    	     (cons 41 19.35)
    	     (cons 40 (* 19.35 (strlen TAG)))
    	     (cons 44 1.0)
    	     (cons 1 TAG)
      (setvar "osmode" 0)
      (redraw)
      (princ)
    Thank you
    f.
  • Thread Tools
  1. Mtext in LISP
    By ticad02 in forum AutoLISP
    Last Post: 2009-04-21, 01:59 PM
  2. Mtext Command in Lisp
    By bowtle in forum AutoLISP
    Last Post: 2009-01-12, 05:47 PM
  3. Create Mtext with entmake
    By TobyKanoby in forum AutoLISP
    Last Post: 2007-06-07, 08:19 AM
  4. Create a Table from mtext and lines
    By tbedrich in forum AutoCAD Tables
    Last Post: 2006-10-18, 03:50 PM
  5. Create mtext (with alter properties)
    By gis.68227 in forum AutoCAD Map 3D - General
    Last Post: 2005-04-14, 03:37 PM
