Thread: Fire Rated Walls - Graphical Representation
    Member MetalliCAD's Avatar
    2005-11
    16
    Question Fire Rated Walls - Graphical Representation
    Is there a national standard or an industry accepted standard for the way fire rated walls are to be represented? Are the linetypes standardized? Just as plant piping has different color codes assigned to them, do the fire ratings for walls have a similar color code? For presentation drawings, all of the various fire rated walls are currently assigned a solid hatch pattern of some "random" color. Is there a standard for this?
    2001-12
    St. Louis
    5,407
    Cool Re: Fire Rated Walls - Graphical Representation
    Quote Originally Posted by timothy.keyser
    I'd be interested to know this as well. We've had two life safety companies prepare drawings for us, and they used hidden linetypes at different scales to represent rating, but, the two companies used different scales.
    I've modified them to be different colors and linetypes for inhouse use, not wanting any confusion upon printing.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Member mead1's Avatar
    2001-06
    Walesville, NY
    21
    Default Re: Fire Rated Walls - Graphical Representation
    good question!
    dunno if these are standard, but i have been using the lines that came out of the box with ADT3
  1. 2015: Filter for Material - Fire Rated Walls
    By david_peterson in forum Revit Architecture - General
    Last Post: 2015-09-23, 09:46 PM
  2. NCS fire rated Lines
    By burchd in forum ACA General
    Last Post: 2009-05-21, 07:42 PM
  3. Using Filter to Control Visibility for Fire Rated Walls
    By hutch_amit in forum Revit Architecture - General
    Last Post: 2008-09-24, 03:49 PM
  4. Graphic solution at fire rated walls.
    By dgraue in forum Revit Architecture - General
    Last Post: 2008-04-22, 09:03 PM
  5. Fire Rated Walls - Thinking Outside the Box
    By tonyisenhoff in forum Revit Architecture - General
    Last Post: 2006-09-06, 05:04 PM
