Thread: ADT2006: Flat elevations of curved walls possible?
    2016-01
    9
    Default ADT2006: Flat elevations of curved walls possible?
    Hi,
    I just wondered if anyone knows the best way to create flat elevations of curved surfaces in ADT2006? Any info much appreciated.
    JP Cota
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: ADT2006: Flat elevations of curved walls possible?
    Please note I moved this thread from CWC to ADT 2006 as this really is where it belongs.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2015-12
    4,730
    Quote Originally Posted by joao_cota
    Hi,
    JP Cota
    Do you mean you have in plan view, walls that have a radius to them? Or do you have mass elements that are curved? What ever it is, you could always try the elevation tool to see what it does to translate the objects to flat line work.
    2016-01
    9
    Thanks for moving the posting - could not find the ADT2006 heading...
    I was considering a 2 storey building (in two separate constructs at two levels). When I have the 3D model, one face of the building is curved. The normal elevation tool provides a projected elevation, the boundary extents of which are the same as the edge lines of the ends of the curved wall.
    How can I get a true flat(tened) elevation of the curved wall in ADT2006?
  1. 2013: Building Elevations Looking Flat
    By TerribleTim in forum Revit Architecture - General
    Last Post: 2013-01-11, 10:51 PM
  2. ADT2006 - ADT walls
    By jaroguy in forum Style Management
    Last Post: 2007-03-02, 03:19 PM
  3. ADT2006: Walls creation from ellipse shape possible?
    By joao_cota in forum ACA General
    Last Post: 2005-11-30, 04:14 AM
  4. ADT2006 custom walls
    By MetalliCAD in forum ACA General
    Last Post: 2005-11-04, 05:36 PM
  5. Curved walls can't have their elevations modified?
    By J-G in forum Revit Architecture - General
    Last Post: 2004-11-12, 03:49 AM
