Results 1 to 8 of 8
Thread: Roof hatch not displaying properly
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,731
    Default Roof hatch not displaying properly
    I got a roasting today from my boss because Revit couldn't display some roof hatching properly.
    If you have a look at the attached screen shot you can see that there is some hatching at the top which displays correctly, but then on the roof under it and on the lower roof I get a grey shade, almost as though the lines have blended together.
    But the thing is, the roof hatching that does display properly is actually a more dense hatch than the one that's not.
    I get the same results when printing to a physical printer, PDF and DWF.
    Since I can't control the line thickness of the hatching, only it's colour I don't know what to do to get around this.
    This is not the only project it is doing it on either. It happens in many others.
    100 Club nrenfro's Avatar
    2003-09
    metro DC
    144
    Default Re: Roof hatch not displaying properly
    I have had the same frustrating experience with roof or sometimes wall hating not displaying properly. I am sure this is not the response you are looking for, but I simply turn off all hatching and fall back on traditional hand drafting conventions. I label each area with text and sometimes (depending on the project) draft in small areas of hatch. Again this is not cool, and something I fight each time it occurres, but it is the only way I a have found to generate consistent output.
    100 Club Nevine's Avatar
    2003-05
    Cincinnati
    123
    in general Hatching stinks in Revit, i have had problems too when sometimes it does not show at all in 3D and it it is not at all user friendly regarding changing hatch scale or origin points.
    I didn't try this myself but I wonder if you change the hatch from model to drafting if it will help.
    2001-07
    488
    I have the same problem when I do PDF's files. I submitted this issue to Revit technical support but they were not able to reproduce the problem, so I still have no answer to the hatching problem, and it is really annoying.
    2003-04
    Chino, CA
    4,756
    Once hatches reach a certain "scale" they turn gray. Change the size of the hatch, or the scale of the view, to get all hatches to show.
    2003-05
    Brisbane, Australia
    1,731
    Quote Originally Posted by Scott Davis
    Definitely not something I agree with Revit doing. It should only turn grey when the lines have a line thickness thick enough, and close enough, to blend them together.
    The current method seems to be a performance thing, but we can't have Revit dictating how our drawings are going to look for issues like this, without providing an override. It is providing inaccurate results.
    But this is a good suggestion, and one that I have had to implement in the meantime.
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Personally, this is a challenge on 3D views more so than elevations. A stone hatch will show properly in the foreground, then it goes to grayscale in the midground and background. I too wish this problem were surmountable. So far, I'm still frustrated with this.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Its awful and it didn't used to be this way, prior to release 4.0 or 4.5 you never had this issue. now its on almost every drawing I do. I've gotten so used to it that I've forgotten to bring it up on the wishlist. The only solution is to find the simplest hatch pattern and make it big enough to avoid the problem. Not always aesthetically acceptable.
    Scott D. Brown, AIA
    BECK
  1. Fonts not displaying properly
    By jeff.benson in forum AutoCAD LT - General
    Last Post: 2010-11-09, 08:32 PM
  2. Thematic Styles Not Displaying Properly
    By dmo1205342273 in forum AutoCAD Map 3D - General
    Last Post: 2010-09-28, 05:56 PM
  3. Underlay not displaying properly
    By mmiles in forum Revit Architecture - General
    Last Post: 2007-07-24, 09:48 PM
  4. Grips not displaying properly
    By jim.dozorec in forum AutoCAD General
    Last Post: 2006-06-29, 04:47 PM
